Ibis 942 Wheels + Bont XR4 Tire Pressure Q- Mtbr.com
Results 1 to 2 of 2
    Dec 2008
    Quick Q - I just built up a new bike (Reeb Dykeluos 2.0) singlespeed and am rolling on i9 hubs laced to Ibis 942's (29" / 42mm Internal) with Bontrager XR4 2.6" tires...fat curious, but not quite and XC+ tires.
    She's a singlespeed, so maximum grip when climbing is important...
    I am coming from some pinner Roval 28mm internal wheels and was running 18psi in back and around 20 in front...
    With the wider rims and tires, I have been experimenting with dropping the tire pressure...not much of a fat biker, and not really tuned in to how low of a psi I can run.
    How low can I go with 42mm rims, and 2.6's? What are others out there doing?
    I am sure that this has been asked quite a bit - feel free to tell me to refer to the search if so...
    Always in the wrong gear
    Reputation: Impetus's Avatar
    Aug 2014
    According to the ibis site, 942s are 41 external and 35 internal. I donít know if your post is a typo, a misunderstanding, or if youíre talking about a different rim.
    I would not mount a 2.6 to an i42 rim.
    Personally, Iíd start with 1-2 psi less than you had on the i28/2.4 combo and slowly drop psi until you get some soft rim strikes, and up the psi 1/2-1 lb.
    I had some i30/2.6 combo wheels in the past and seem to recall I was happy with 15f/17r at 155-160#, also on a singlespeed bike.
    You also posted you run a higher psi in the front than back, which is unusual.
    FWIW, I have the 29x3.0 XR4 at 9.5-10 psi (i43 rim) on the front of my bike and love it.
    Donít modify the trail to match your skills, modify your skills to match the trails.
  1. Replies: 3
    Last Post: 1 Week Ago, 08:01 AM
  2. Bont Riot + MTB Shoe? LG, PI, or Bont?
    By derek1387 in forum Apparel and Protection
    Last Post: 09-23-2018, 05:08 PM
  3. Purchasing 942 Wheels
    By chowdapilot in forum Ibis
    Last Post: 09-02-2017, 05:56 PM
  4. 2nd guessing my LBS built Ibis 942 wheels - would you rebuild?
    By sam-eye-am in forum Wheels and Tires
    Last Post: 07-03-2017, 03:44 PM
  5. Ibis 941 / 942 compatible tire combos
    By Giff06 in forum 29er Components
    Last Post: 03-23-2017, 01:51 PM
Members who have read this thread: 17
