I want to change the tires on my girlfriends bike to road tires.- Mtbr.com
Results 1 to 8 of 8
    Aug 2010
    Right now I currently have 24x1.95 mountain bike tires on the bike and I want to put a smoother road tire. How would I go about doing this? Do I have the change the inner tube? What size road tire do I buy and what is a decent in expensive tire I can put on the rim? What else can I do to the "Toys r' us" mountain bike to make it into a street bike?
    Unfit Norwegian
    Reputation: Dazed's Avatar
    You can't fit "road tires" (ie. 700C/ETRTO 622mm) to a ETRTO 559mm mountain bike rim. I assume you mean 26" and not 24". There are many different slicks you could use. Look at Continental Sport Contact and other such tires. I like Schwalbe Kojak.
    Aug 2010
    I wanted to change to a smoother tire for street riding. It really a 24" not a 26".
    Unfit Norwegian
    OK. It's some kind of dirt jump/stret bike, then?
    Anyways: look for a high volume street tire with small/tightly spaced knobs. I believe the Intense Microknobby comes in 24", for example. Beware that street/DJ tyres are often heavy.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    If you want slicks, Schwalbe's Kojak also exists in 24"x1.50". Their Big Apple is bigger at 24"x2.0" and 2.35".
    Not cheap, I believe.
    is your girlfriend actually complaining about the tires?
    you should just save the money for a real bike instead of a toysrus bike.
    Reputation: louisssss's Avatar
    get her a real bike instead of some walmart bike... Cannondale Quick, or some other cheap hybrid with 700c wheels.
    RH SL Pro
    Aug 2010
    Just picked up one for her. Didn't want to spend a lot being that she probably wont be riding the bike in 3 weeks anymore
    http://forums.mtbr.com/showthread.ph...00#post7278300
