Hub Play- Mtbr.com
Results 1 to 5 of 5
Thread: Hub Play
    Hub Play
    Trying to get a sense if this hub play is correct. Brand new bike, not ridden on the trail yet. Front hub spacer/cap has wiggle play in it.
    https://youtu.be/AJkCcxuSP4o
    When tightened in the fork there is still play that you can feel when moving rim around as well as hear.
    https://youtu.be/RnXA7n7qT4I
    Thoughts?
    If brand new means from a shop check the front wheels of any others in stock including other models using the same wheelset or hub. The service techs should be able to check your hub. I like to check other examples first.
    I wouldn't like that play.
    Thanks. Yes went to LBS and no play in other MTB's on floor.
    Jan 2009
    I'd take it back to the shop where you bought it and have them take a look. Without any specific information about the model of the bike or the hub, there's no way to tell what's happening there.
    I would expect the cap to be loose with the wheel off the bike, but a properly tightened front axle skewer should snug it up.
    I had a brand new Hope hub with a bad bearing. It happens. Have the shop take care of it.
  1. Dt Swiss Onyx style hub 370 free hub body play.
    By C.M.S in forum Wheels and Tires
    Last Post: 07-28-2014, 08:04 PM
  2. Hub Play - I9 Torch Classic Front Hub
    By Cusco in forum 29er Components
    Last Post: 05-17-2014, 08:35 AM
  3. Hub Play - I9 Torch Classic Front Hub
    By Cusco in forum Wheels and Tires
    Last Post: 04-21-2014, 02:21 PM
  4. Hub Play Tolerances?
    By mtec in forum Wheels and Tires
    Last Post: 02-01-2011, 10:25 PM
  5. Replies: 0
    Last Post: 08-11-2006, 02:00 PM
Members who have read this thread: 24
