Hub Grease?- Mtbr.com
Results 1 to 10 of 10
Thread: Hub Grease?
    Hub Grease?
    Hey everyone. I have Bontrager line comp 30 wheels and Iím doing the popular upgrade of going to 108 poe as well as replacing the Shimano driver to XD. Apparently I need bontrager hub grease to install properly. Are there any other alternatives to use for grease? Lithium grease OK?
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Do you know if that is a light or heavy grease?
    I use Pedro's synthetic for just about everything, it's fine inside Hope hubs.
    Taking apart the hub, the pawls have this gooey stuff for sure. Not thin.
    Mar 2012
    I've never had a 108 poe hub but generally any thin grease is fine in my opinion. Lithium grease is good, I've also used slick honey. Just don't use to much causing the pawls to stick.
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ yeah. Something thin and non-sticky is best. If the pawls are slow to engage, you can wind up putting a lot of force on them before they fully engage and damage pawls or the ratchet ring. This is a pretty common problem and cold can make it worse.
    I find that a small amount of Slick Honey can be OK. I also use gear oil on some hubs. Dumonde Tech makes a specific pawl lube which is very good. If the freehub is louder, it means the pawls are moving faster, which is a good thing.
    Do the math.
    Interesting. The goop that is in there now seems thick? Almost like vasoline.
    Feb 2006
    How old is the stuff in there?
    Itís bontrager line 30 comp wheels off a 2018 so bit old at all.
    Never trust a fart
    Reputation: frdfandc's Avatar
    I normally use either Slick Honey, or Phil's Tenacious oil for hubs. Never had a problem.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by ejewels View Post
    The old, gummed up stuff can't really be used to determine the characteristics of the stuff that was used.
    Think about how gummy chain lube can get when it's old and full of dirt. Or what happens to the light lube shimano puts in its shifters after years and years of use (it gets gummy and the shifter starts misbehaving, requiring that you hose the thing out with degreaser and put fresh lube in).
    I've been using Phil's Tenacious Oil in my hubs for years, and when it gets old and dirty, it gets thick and gummy, too, totally different from its properties fresh out of the bottle.
  1. Grease or no grease
    By roadscuzz in forum Weight Weenies
    Last Post: 07-19-2013, 07:51 AM
  2. What Type of Grease for Grease Ports?
    By B-Line in forum Santa Cruz
    Last Post: 10-28-2012, 05:06 PM
  3. Grease gun and grease recommendation
    By wonny in forum Intense
    Last Post: 10-17-2012, 11:35 PM
  4. To grease or not to grease......
    By OutThere in forum Bike and Frame discussion
    Last Post: 04-25-2012, 01:39 AM
  5. Replies: 12
    Last Post: 12-22-2007, 06:13 AM
Members who have read this thread: 59
