Hub ball layout- Mtbr.com
Results 1 to 8 of 8
Thread: Hub ball layout
    No Fear
    Reputation: Iranian-Mechanic's Avatar
    Hub ball layout
    hello every body i have a question about the placing & layout of balls in non ballbearing hubs !!!
    What are non ball bearing hubs called in English ?
    My question is that when you put all balls in place there is a gap between the balls that another ball can not fit in ...
    Why is it so ?? and doesnt this gap make all the balls to be in a unsuitable position ? or isnt the weigh & force distributed unevenly in this situation ???
    Reputation: life behind bars's Avatar
    May 2014
    In "cup and cone" bearings the load is more or less distributed evenly around the circumference of the bearing races.
    "These things are very fancy commuter bikes or really bad dirt bikes, but they are not mountain bikes." - J. Mac
    No Fear
    Quote Originally Posted by life behind bars View Post
    Thanx a lot so their called cup & cone hubs........
    The hub in the picture is called a cup and cone, or loose ball hub. The other type is called a cartridge bearing hub, but some call them sealed bearings. Cartridge bearing is correct though.
    The less loose balls you have in there, the less friction. I think they leave the gap to decrease friction and allow room for grease? Im sort of guessing though. On higher end loose ball hubs, they include plastic bearing spacers.
    If there was no [slight] gap, the bearings would rub against each other, which is undesirable.
    Cartridges (and some "loose" bearing hubs) use a spacer to keep the balls from touching, and in the special full-compliment cartridge bearings, they have a small gap, as well.
    Reputation: LyNx's Avatar
    As has been said, those are Cup & Cone hubs. There has to be space between the bearings to allow for grease and movement or else the balls would bind and not move/spin smoothly. In general you find this setup on lower end hubs or on all Shimano hubs. It's actually a pretty good system, but not as easy to service as just popping out cartridge bearings and replacing them, the adjustment isn't as easy and they generally require a bit more maintenance/service to keep them running smoothly.
    Bit of an FYI, if you're going to be servicing a hub, especially cup & cone, where there's a good deal of grease, best to remove the rotors from the hubs instead of risking getting grease on them and having to deal with that. Also take your time when adjusting them, you need to just take out any play, no tighter or they will start to bind. Shimano actually make a tool AFAIK to help with this, so if you're going to be working on a lot of them, might be worth looking into.
    No Fear
    Thanx to all for their help
    So by the things i understood from the posts even if there is enough space between the balls fora another ball to fit in but it causes the balls to rub against each other
    Its better to leave that empty space alone right ?
    in the case of center lock rotors i do so but for 6 bolts..
    Noooo i prefer cleaning the rotor after wards with alcohol than to open up 6 bolts and installing them again specially that all of them often have locktite on them and opening & closing them all again is a pain in the ***
    what is that tool ?
    Reputation: Lone Rager's Avatar
    Dec 2013
    Quote Originally Posted by Iranian-Mechanic View Post
    ... but for 6 bolts..
    Use an electric drill/driver to turn the bolts in/out. I manually break them free and torque them only using the drill/driver to do all the turns in between.
    Do the math.
  1. Post your Bikepacking Rig (and gear layout!)
    By rusheleven in forum Bikepacking and Bike Expedition
    Last Post: 1 Week Ago, 03:40 AM
  2. Replies: 1
    Last Post: 08-01-2011, 07:05 PM
  3. OT, What's with the new layout?
    By emu26 in forum Lights DIY - Do It Yourself
    Last Post: 06-06-2011, 06:52 AM
  4. Using LiDAR for layout
    By special O in forum Trail Building and Advocacy
    Last Post: 05-05-2011, 07:52 AM
  5. New Tool Trailer Layout
    By SofaKing Fast in forum Trail Building and Advocacy
    Last Post: 04-20-2011, 06:49 PM
Members who have read this thread: 41
