How to Patch an Inner Tube- Mtbr.com
Results 1 to 15 of 15
    Reputation: shiggy's Avatar
    Dec 1998
    Yes, they are still useful and easy to repair. I added a short How-To on my tire site.
    mtbtires.com
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    That's perfect - I'll show the link to my friend who is still bewildered about patching his own tubes
    "Life begins at 140" Richard Burns
    http://www.nikolay-k.com
    More Torque
    Reputation: Diesel~'s Avatar
    Quote Originally Posted by shiggy
    Good reminder. I'm always amazed at how many folks don't take the time to patch their tubes. Saves $ and keeps waste out of the landfills.
    I've had good luck using a screen installation tool to roll over the patches and help them to stay down.
    -D
    Great tip Shiggy...I have been have some trouble with patches staying put, which is frustrating...i will try the lever.
    Dec 1998
    Quote Originally Posted by rafdog
    Follow every step. They are all important for best results.
    mtbtires.com
    Reputation: hikerdave's Avatar
    Mar 2006
    I would add a few steps.
    - Rub the patched tube in the dirt or with talc so that the patch won't stick to the inside of your tire.
    - If possible, wait for a day or two before using the patched tube. (This tip is from advice written by Jobst Brandt.)
    "Thank you, God, for letting me have another day"
    The Milagro Beanfield War
    Dec 1998
    Quote Originally Posted by hikerdave
    I tend to leave the plastic on the top.
    I also with use the tube immediately, if possible. The pressure of tube against tire works as well or better than waiting a few days.
    mtbtires.com
    right-on, good info., im using maxxis ultra-lights, so this will be key info...
    thanks
    Shiggy - GREAT stuff! So many people ruin the world by touching the tube, the patch backing, or the glue. Now no one will have an excuse to mess up a patch ever again! The only problem is, it'll make selling tubes a little harder...
    Shiggy, what do you think of self-adhesive patches, like the Slime branded ones? I've used a few to patch some tubes that I have lying around, but haven't put them back in a tire yet.
    Quote Originally Posted by rmccully
    In my experience, those are only good for temp fixes.
    Oh noes. I'm going to drink the Kool-Aid.
    Ride, Sleep, Work
    Reputation: MichaelW's Avatar
    I know how to patch a tube.
    1. Run tubeless
    2. Get a new tube.
    Not meaning anything by this. I am joking
    I hope I remember the steps the next time I flat on the road.
    Click to save 15% off your 1st Hammer nutrition order
    http://www.hammernutrition.com/affiliates/50110
    Dec 1998
    At best, self adhesive patches are a temporary fix to get you home. Every one I have tried has failed later and was replaced with a real repair.
    If your patched tubes have been sitting around for more than a few weeks I would bet they will leak.
    mtbtires.com
    Dec 1998
    Quote Originally Posted by MichaelW
    1. Run tubeless
    2. Get a new tube.
    On the road/trail you should carry a couple of spare tubes. Swap the tubes (after inspecting the tire for foreign objects) and repair the tube at home. Patching a tube on the trail is a last resort.
    mtbtires.com
    Better advice would be to put the tube in the tire and inflate it right away.
    I've done 100's of patches this way without a single failure.
