How much of rear flex is due to rear wheel?- Mtbr.com
    I have some Arches on my bike now and am starting to hit bigger jumps, drops and more tech. The rear seems pretty flexy so I'm considering putting a new hoop on it.
    Will it make a big difference in feel and stiffness?
    Any recommendations? I'm hoping to not spend a lot since it's non-boost.
    Reputation: minimusprime's Avatar
    Quote Originally Posted by bank5 View Post
    Depends on the make/model of frame and the wheel. Stan's arch's are a bit flexy but not as bad as some. You won't notice much difference going to another aluminum wheel in my opinion. You'll get maybe 10-15% subjective improvement in stiffness. Much of the stiffness concerns we have in full suspension bikes have much more to do with teh frame then the wheelset however.
    I agree with minimusprime... hard to say without first hand testing.
    A couple of thoughts...
    Stans rims can be a little fiddly. I have built some Crests... super light, but very flexy.
    Their rims tend to be sensitive to tires and pressures... I would check your spoke tensions... tension could have gone South in the wheel. I highly recommend final tensioning of Stans rims with tire mounted and aired up to pressure.
    If you rebuild, I would consider upping the spoke count. I generally go straight to 32 for off-road work. It doesn't really add much weight, but it really helps strength and stiffness. (I know this might mean a new hub too, but worth it)
    TTUB - Ventura County California
    Thanks for the replies.
    Currently have 32 spokes. The bike is a BMC speedfox. I'm first going to replace the linkage as I'm getting some creak and it's been a while since I replaced it.
  1. Replies: 0
    Last Post: 02-03-2012, 04:21 PM
  2. Rear flex vs. Wheel flex
    By rekibtm in forum General Discussion
    Last Post: 07-10-2008, 07:27 AM
  3. Trance flex? I can't find no flex
    By Gripshiftrules in forum Giant
    Last Post: 06-19-2007, 08:32 PM
  4. rear triangle flex -- How much?
    By Jwind in forum General Discussion
    Last Post: 08-09-2006, 07:32 PM
  5. How much flex in a wheel is normal?
    By robgreat in forum Wheels and Tires
    Last Post: 05-08-2005, 04:46 AM
Members who have read this thread: 27
