how to get the core out of a presta valve?- Mtbr.com
Results 1 to 5 of 5
    What tool do I need to use and how do I do it? Thnx
    Did you mean Schraeder valve, Presta cores are NOT removable.
    Quote Originally Posted by Ironbar
    I've had to toss only a couple defective ones due to faulty valves in about 15 years of riding. When you buy them, look for thin or stressed rubber around the base of the stem, often this is a sign of a low quality tube. My defective ones were Fishers, I only buy Pyramid mostly anymore, which are made by Kenda and very affordable. I've actually had good luck with Performance tubes too.
    thnx for the input bro but I'm looking to fill the tube with slime, and need to remove the core for that reason.
    Reputation: shiggy's Avatar
    Dec 1998
    Conti and Schwalbe tubes have removable presta valves. Other than those you can force the locking nut off the valve pin and let the core drop into the tube. After you put in the Slime, find the core, work it back into the valve stem and replace the nut.
    I would just get the Conti or Schwalbe tubes.
    mtbtires.com
    Quote Originally Posted by shiggy©®™
    That sounds like the move, thanks for the scoop
  1. Schrader valve extender for rear fork
    By Moo Shoo Pork in forum Shocks and Suspension
    Last Post: 03-09-2004, 10:25 PM
  2. Losing air from tubeless valve
    By T3man in forum Wheels and Tires
    Last Post: 03-01-2004, 12:02 AM
  3. Stan's notubes valve stem hole enlargement
    By Eltbee in forum Wheels and Tires
    Last Post: 02-25-2004, 01:06 AM
  4. Advice with Stan no tubes sealent ?
    By Johny Rotten in forum Singlespeed
    Last Post: 02-13-2004, 03:39 PM
  5. Suggestions for WW FAQ section
    By Trevor! in forum Weight Weenies
    Last Post: 01-19-2004, 01:22 PM
