how to get consistent readings from Park Tool tensometer- Mtbr.com
Results 1 to 7 of 7
    I've noticed that the reading from my Park Tool tensometer can vary by as much as 2 depending on how quickly or slowly I release the handle. I've also noticed if after releasing if I give it a few taps with a pencil, causing the tool to vibrate, it seems to consistently settle on the same reading (for a given spoke). Is doing this something you would recommend?
    Reputation: WHALENARD's Avatar
    Feb 2010
    I try to go with consistency. Releasing in the same manner (slowly) and in the same area as the spoke (toward the middle). Also so the 2 grabbers engage the spoke at the same time/flush. I accept that the park tool is not the most accurate thing out there but with those things in mind and some patience is better than using no tension meter. Curious to others thoughts on it as well.
    Sent from my moto g(6) forge using Tapatalk
    It is no measure of health to be well adjusted to a profoundly sick society.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I lube mine with a little Phil Wood Tenacious Oil. Seems to help. I also check every spoke twice. Set the tool on the spoke, release it, grab it again. Takes a tiny bit longer but seems to work.
    I like turtles
    Reputation: J.B. Weld's Avatar
    The tool should be horizontal to the ground and released slowly. Also it should be in the middle of the spoke. If nothing else I've found the Park tension meter to be very consistent, I could check the same spoke 10 times and get the same reading every time.
    I brake for stinkbugs
    Feb 2010
    Quote Originally Posted by NYrr496 View Post
    I'll do that as well if I don't like the reading. If I get a spoke that's out of whack I'll make sure it's not wound up and destress it checking it several times until I'm happy the reading is accurate.
    Reputation: Lone Rager's Avatar
    Dec 2013
    I noticed some have friction where the indicator passes through main plate at the dial. I've carefully tweaked mine to eliminate this.
    On another note, I brought mine to the LBS and compared it with 3 different mechanic's TM-1s on some different wheels/spokes and they were all within 1/2 division, which was somewhat surprising as they varied a lot in age and apparent use.
    Do the math.
    I sanded mine where the pointer slides. The blue coating was extremely rough. That, plus a drop of oil every few months, and it's very consistent now. Much much better than new.
  1. Keep suspension consistent? Coil vs. Air + Fork vs. Rear
    By BJG718 in forum Bike and Frame discussion
    Last Post: 02-02-2019, 08:46 AM
  2. Giant Tool Shed Multi-Tool - Ten Bucks - incl. chain tool
    By aa240sx in forum Where are the Best Deals?
    Last Post: 06-23-2011, 11:17 AM
  3. How to get consistent SPD release force?
    By beanbag in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2011, 05:47 AM
  4. General tool set or tool by tool?
    By jnstrom in forum Tooltime
    Last Post: 03-17-2006, 08:02 PM
Members who have read this thread: 85
