How to disassemble this hub?- Mtbr.com
Results 1 to 30 of 30
    Jun 2016
    So I have a Salsa Timberjack SLX 27.5+ 2019. The rear hub is making an annoying hum, and I wanted to put some lube and see if it solves. Weird enough I couldn't disassemble past the caps and axle. Looks like there's a tool needed, that I've never seen before:
    Tried to identify which hub is that, looked into the TJ topic, and seems that my hub is not the same as that one. Also the Salsa web page does not contain any information about that hub.
    To make things weirder, the spline on the picture above is wider than the inner diameter of the bearings, meaning that I probably need to remove one of the bearings to insert the tool (assuming that that's the right way to disassemble this hub).
    Has anybody ever seen this?
    Jul 2019
    Quote Originally Posted by fmendes View Post
    That is not a tool point. Pics would of what you ae trying to remove.
    are those white ind xmr hubs?
    Jun 2016
    Quote Originally Posted by Outhouse View Post
    That is not a tool point, your going to have to remove/unscrew both axle caps. Cannot tell based on picture.
    Thanks. I did that. What you see (orange, out of focus) is the bearing that is behind the axle cap. In this picture, the axle and caps were removed. Still the freehub won't come out.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    just guessing here
    a picture from the freehub side
    will be more informative about your freehub side of the hub
    than a picture from the brake side
    I know it's a stretch....and almost sounds like a fairy tale, but humor us
    in my experience with modern hubs you just have to yank hard to get things
    to pop off....might be an o-ring holding it in
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Jul 2019
    firm pull usually pulls the free
    since 4/10/2009
    Reputation: Harold's Avatar
    sometimes helps to install the cassette so you have something you can grab/pull. especially if that freehub body has been installed for a long time.
    Jun 2016
    I'll try again. I'm a strong person, and pulled already. Didn't move a hair, but will take pictures and try again.
    Jun 2016
    So I tried again. Used considerable force, just enough to prevent bending the big cog on the cassette. Didn't move a hair.
    I noticed that the axle is supported by two bearings only. Based on that observation I deduct that there must be another bearing between the body of the hub and the freehub. The freehub spins on the hub when the axle is not in place, confirming the presence of the bearing. Still not the most common construction. Hope will last at least one year.
    More info:
    - Although being a budget bike, the internals of this hub are mostly steel (axle and freehub).
    - 15 POE, and is a very silent hub, except for the humming.
    - The bike is 2 months old, so I may just throw the towel and let the LBS take care of it.
    - Of course I also tried to pull after removing the axle and caps, and didn't move.
    - When I spin the freehub, the internal spline does not move.
    Attached Thumbnails Attached Thumbnails How to disassemble this hub?-img_20190916_182514.jpg
    Reputation: J.B. Weld's Avatar
    Shine a light inside the free hub and see if there are any flat sides down there, some hubs use a giant hex wrench (14mm?) to unscrew the freehub from the non- drive side.
    There isn't much to grease or oil though, you can pull the seals on cartridge bearings but mostly when they're bad you just replace them.
    I brake for stinkbugs
    Oct 2018
    although i dont have an answer i would like to add that im in the same boat with one of the wheels i have.
    OP, it looks like the inside of the freehub uses some sort of spline tool like a cassette removal tool...right? most ( that i have ) have a 6mm hex. loosen and it comes right off.
    i just figured i didnt have the right tool and havent got back to that wheel yet.
    im surprised to see this up here with out an immediate answer. i figured it was a simple tool answer...maybe still is?
    I didn't see the first pic until now, needs a big a$$ hex wrench.
    Oct 2018
    Quote Originally Posted by J.B. Weld View Post
    its not though. it has many spines
    Jun 2016
    Quote Originally Posted by Special Eye View Post
    Yes, there is a spline, but is much bigger than 6mm. Considering that the thru-axle is 12mm, the spline has to be at least the same size, or bigger. But then, to reach that spline, I have to remove the bearing, as the ID of the bearing is also 12mm...
    That may be. Having 12 splines, is very plausible that a 14mm allen key would work. Still I'm puzzled by a design that requires to remove one of the bearings just to access the freehub. I wonder if I want to potentially destroy one bearing just to get rid of this humming.
    Still, thanks for all the answers. Looks like reaching that spline is the way to go.
    I think it has 12 sides so the axle will clear but a 6 side hex will still fit.
    You only have to remove the non-drive side bearing, it won't destroy it.
    Again though, if the bearings are bad they'll need to be replaced anyway and if they're not you may be trying to solve the wrong problem.
    Looks like a Formula hub. The hex nut is 11/12mm depending on the hub design. Usually, removing the freehub doesn't require removing bearings.
    I'm willing to bet, that unless the OP has worked on these hubs before, or is at a bike shop, they probably don't have hex keys in that size range.
    Jun 2016
    Thanks for the help! Now it's just a matter of eyeballing the right tool. Will take the tool to the hardware shop and figure out.
    Reputation: Tribble Me's Avatar
    The inside first picture kinda looks like the inside of the Shimano freehub I'm trying to get off, which is supposed to take a 14 mm hex wrench. Please let me know what works for yours.
    Jun 2016
    Quote Originally Posted by Tribble Me View Post
Name:	Screen Shot 2019-09-17 at 1.37.44 PM.jpg
    Not exactly that, but the picture looks promising. I'll pass by a hardware store as soon as is safe to drive around (I'm around Houston, and Imelda is coming tonight). The design of the Shimano hub seems better than the hub I have, that only allows inserting the tool from the non-drive side.
    But I looked into the Park Tool site, and looks like the 14mm allen wrench is the one used for Shimano freehubs:
    https://www.parktool.com/product/14mm-hex-wrench-hr-14
    Yes, but I have a 14 mm allen that won't quite fit but I've ordered an HR-14 to see if that'll work.
    Hope Imelda passes safelyand quickly by you and everyone else in its path.
    But an HR-14 is a 14mm allen
    I hoping that the problem is that the 14 mm allen I have is just too big. It measures slightly more than 14 mm. I'm not sure how tight the tolerances are on the hub.
    bike tester
    Reputation: syl3's Avatar
    some shimano hubs take a 15 mm hex, double check before you strip the bolt
    Quote Originally Posted by syl3 View Post
    But the 14mm he has is too big. Seems extremely unlikely that a hex wrench would be that far out of spec but I suppose it's possible.
    It's made for a large hex, Kona uses the same interface for their suspension pivot bolts. 12 pt will fit a 6 pt hex even if it looks odd
    Jun 2016
    At least that would be easy to solve, with a Dremel. Still puzzles me that nobody had (so far) a positive answer about how to open these hubs. I though it would be a silly question, but seems it is not. I'll try the 14mm wrench tonight, and grind if needed. At least I know I don't need to grind a 15mm...
    Perhaps it's a 12 or 13? Might be easier to take it to a shop and have them try different sizes and then you'll know what to use rather than destroying a hex.
    83 Ritchey Everest
    88 Mountain Goat Whiskeytown Racer
    95 Bianchi Mega Tube ti
    2012 Ibis Mojo HD
    2015 Kona Process 153
    Nobody? Hex wrench, the right size. Grinding one to fit doesn't seem like a good idea to me.
    Reputation: Lone Rager's Avatar
    Dec 2013
    I have run into hubs that took a 13mm. I have an oddball 13mm L allen wrench to use just for that purpose.
    Do the math.
    Jun 2016
    I bought a 14mm wrench, but didn't even test it. I was starting to feel a little ridiculous risking to damage one of the bearings just to (maybe) fix the humming.
    So the problem is temporarily solved by putting a generous amount of teflon oil (the same I use on my Hadley hub) inside the hub. Improved a lot. When the hub breaks, I come back to the subject, if I don't decide for a better hub.
    Jun 2016
    So, from this other thread, I got some light. This is the hub (WTB Serra):
    https://cdn.shopify.com/s/files/1/02...0326v3.pdf?651
    And from the manual (surprisingly decent), it reads:
    The freehub is removed from the hub using a 14mm hex key once both the bearing nut and end cap are removed from the drive side. Insert the 14mm hex key into the non-drive side of the hub and slide it through until it engages with the freehub body carrier (8) on the drive side. Looking at the non-drive side of the shell, rotate the 14mm hex key clockwise to remove it from the hub shell.
    Mystery solved 100%! Thanks to all.
  1. Anybody Ever Disassemble a DT Swiss Tricon Hub?
    By OneEyeMan in forum Wheels and Tires
    Last Post: 07-08-2013, 07:56 AM
  2. how to disassemble avid levers for lever replacement?
    By harryzhong in forum Brake Time
    Last Post: 11-10-2011, 12:09 PM
  3. disassemble my Lefty
    By stef j. in forum Shocks and Suspension
    Last Post: 11-09-2011, 01:52 PM
  4. How to disassemble a Hope Pro2 150mm
    By tiSS'er in forum Wheels and Tires
    Last Post: 07-20-2011, 08:12 PM
  5. How do I disassemble V brakes?
    By rc51kid in forum Brake Time
    Last Post: 03-21-2011, 07:19 PM
Members who have read this thread: 105
