Results 1 to 18 of 18
    Positively negative
    How big are these 2.6" tires really?
    I have seen some pictures and herd some reports that some of the 2.6" tires on the market are actually measuring closer to 2.4". I have a bike with 2.4" Trailbosses (that measure ~2.4" on 25mm rims) that I think would benefit from bigger, or if possible taller, tires but don't wanna spend the money on rims and tires for no real changes.
    Anyone have measurements on any of these new tires? Rim width, tires width, and tire height would be ideal.
    Reputation: Steel Calf's Avatar
    Feb 2010
    The Nobby Nic 2.6 are 65-66mm wide on a 35mm inner width rim. If you choose a slightly narrower 30mm rim the tire will shrink by 50% of the subtracted width = 66mm - 0.5*5mm = 63.5mm
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    Quote Originally Posted by Steel Calf View Post
    This. My NN 29x2.6 on 35i rims are 65mm.
    Oct 2015
    I have Maxxis Rekon 2.6 on a 29mm inner rim. I was previously running Ardent 2.4 on the rims and they measured true 2.4 at riding presure. The Rekon measures 2.5 at riding pressure after some miles an stretching by pumping to max inflation while the bike is at rest between rides.
    Although 1/10th of an inch (2.5mm) doesn't sound like much, the Rekons have significantly more volume and grip than the Ardent. It was a very noticeable performance increase. Rolling resistance increased on hardpack, but it was a fair trade. Plus, they look so bad@$$ on my Trance.
    Feb 2010
    Quote Originally Posted by erb16 View Post
    could you post some pictures showing frame clearance with these tires?
    I'm thinking about Nobby Nic 2.6 on a 30mm rim rear / 35mm rim front
    Purveyor of Trail Tales!
    Aug 2005
    Quote Originally Posted by big_papa_nuts View Post
    Hi Mr. big_papa_nuts,
    I don't have tire height for you but my Schwalbe Nobby Nic 29" x 2.6" tire mounted on Derby 29 mm ID width rims measure 65 mm (2.56") at the sidewalls when aired up to 16 psi. It's one mm smaller when measured at the side nobs. I did leave the tire mounted up for a few days at 40 psi before it "stretched" to that width at my normal riding pressure of 16 psi.
    I've ridden it quite a lot in the last few months and really like the tire!
    Good luck,
    Michael
    If you can't keep the rubber side down......at least smile for the camera!
    Oct 2015
    I have the hardest time getting pics from my phone to the forum.
    There is a min of 6mm and a max of 8mm all around. The tightest clearance is at a weld on the vertical brace between the tire and seat tube.
    Feb 2010
    If you use tapatalk on your phone to access the forum it's as simple as it gets
    Jan 2009
    2.6" tires are about two and six-tenths of an inch.
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    Quote Originally Posted by mack_turtle View Post
    No way! It's more like 2 and 3/5'ths.
    My name is Chris and I ride a Prophet 650b with a Lefty.
    Reputation: wooly88's Avatar
    Just mounted Rocket Ron 2.6's on Ibis 742 rims and they're 2.6 on the dot. I assume they'll stretch a bit.
    Positively negative
    Seems like the rim could make a noticeable difference.
    Quote Originally Posted by Just J View Post
    I measured the 2.6" Nobby Nic on an Ibis 741 rim with a 34mm inner width for comparison:
    2.579"
    Then I moved the 2.6" over to the Czero rim:
    2.487"
    Then I moved on to the 2.6" Rocket Ron on the rear Czero rim:
    2.458"
    Oct 2015
    How big are these 2.6" tires really?-screenshot_2017-05-28-08-34-49.jpgHow big are these 2.6" tires really?-screenshot_2017-05-28-08-35-27.jpgHow big are these 2.6" tires really?-screenshot_2017-05-28-08-35-10.jpg
    Reputation: MSU Alum's Avatar
    Quote Originally Posted by wooly88 View Post
    I'm just about to get a pair of 742's (my wife's getting the 735's). My RR's are more like 2.48 on smaller rims....looking forward to seeing the difference.
    Positively negative
    2.6 Nobby NIC on WTB KOM i29.
    Also tried a 2.8" WTB Trailblazer, which fit in my standard Pike but only had 2.5mm of clearance. So I guess I'm now searching for narrow/short 2.8s.
    Quote Originally Posted by alexbn921 View Post
    My Knobby Nic 29x2.6 tires are around 2 5/8ths wide at 20 psi.
    A 35 mm internal rim would be a better fir IMHO.
    As far as how big? My Nic 29x2.25 were exactly 29" high, and a circumference of 90", the Nic 29x2.6 is 29.5" tall, and 92 inches in one revolution. Width as mentioned is 2-5/8" eyeballing it.
    Oct 2015
    Bump. Anyone measured the WTB Trail Boss 2.6? Or any WTB 2.6?
  1. Big Boy (6'6", 250lbs) need help finding a big fat bike 5" tires
    By jaggittens in forum Clydesdales/Tall Riders
    Last Post: 11-09-2016, 07:37 AM
  2. Replies: 3
    Last Post: 03-16-2016, 03:11 PM
  3. Replies: 0
    Last Post: 02-02-2016, 04:44 PM
  4. I really really really need a {34 tooth} 9 or 10speed front chainring
    By squareback in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-16-2014, 09:59 PM
  5. Replies: 8
    Last Post: 10-22-2012, 09:50 PM
Members who have read this thread: 99
