High pressure pump for tires?- Mtbr.com
Results 1 to 3 of 3
    I realize this is probably a stupid question for some of you, however I do not know the answer. (of course) Can I use a high pressure pump (like the ones for my rear shock) to air up my tubes in my tires?
    Thanks in advance for your answers.
    MV
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by malariavalley
    MV
    Yes, but they are very low volume and it would take along time.
    mtbtires.com
    I've had to use mine a few times where my regular pump won't seal well enough to get upto pressure, thankfully just to get the last bit in but even that takes AGES.
    Switched to a Lenz pump with screw on valves haven't had to since switching to that thankfully, much better retro design than these self changing clip on jobs.
