Help!!!!- Mtbr.com
Results 1 to 9 of 9
Thread: Help!!!!
    Reputation: SS-Rider's Avatar
    Feb 2006
    Help!!!!
    ok so I'm tighing my spoke's & now the brake pad on the left is rubbing up against the rim what do I do now?????? sort of a noob at this
    Reputation: shiggy's Avatar
    Dec 1998
    Re-dish the wheel
    mtbtires.com
    Feb 2006
    um..
    how do I re-dish the wheel? sorry new to messing with wheels
    Dec 1998
    http://sheldonbrown.com/wheelbuild.html
    Let me guess: You tightened the all left side spokes on the rear wheel.
    mtbtires.com
    Reputation: gmats's Avatar
    Apr 2005
    Basic idea is.....think of your wheel as right side/left side. If you tighten the spokes on one side of the wheel, the wheel will be centered (dished) to that side. If you loosen the spokes on one side, the wheel will be centered away from that side. If you tighten evenly on both sides, then the wheel will stay centered on that side but will pull that part of the wheel towards the hub (away from the tire). Hope that helps and makes sense.
    aloha,
    g
    Just make sure that neither side is over tensioned. If you have tightened too much on one side and try to pull it abck you could over tention it and cause problems.
    If you feel this is the case just loosen the side it is going to and it will move back.
    Either way start at a nipple and work around the wheel, set the spokes (squeeze about med pressure) and then again as needed.
    As well NEVER go more than about a 1/4 turn (quarter turn) per time around or you risk over doing it.
    KIN
    Feb 2006
    Thanks sorry about the noob question been riding for a while but never really done anything but cleaned & changed my tires!
    Apr 2005
    Quote Originally Posted by SS-Rider
    No worries. We have to learn some how. Good luck, hope it all works out.
    aloha,
    g
    Feb 2006
    Crap...
    now it seems to be worse it's still rubbing I think I might have to take it to my LBS I hope I can figure this out
