having trouble getting rid of flat spot on new wheelset....- Mtbr.com
Results 1 to 3 of 3
    k2x
    k2x is offline
    Caution;  Merge;  Workers Ahead! having trouble getting rid of flat spot on new wheelset....
    I just bought a new wheelset from PricePoint (Mavic 717/XT) and whomever laced it up did a pretty shotty job. Both came out of true with a nice flat spot in them. I pulled them apart and relaced them but I'm having trouble getting rid of the flat spot. Any guidence or suggestions??
    k2x
    Don't overlook the potential that the flat spot is in the rim itself which probably won't be something you can fix with spoke tension.
    nachos rule!
    pretty much all rims have a small flat spot at the joint, some much more than others. if that's the case there's nothing spoke tension can do to change it. pretty much a non issue though, once you slap on a 2.1-2.5 tire you'll never know it's there.
    plus a change, plus c'est la m'me chose - alphonse karr
  1. Replies: 1
    Last Post: 08-15-2004, 11:45 AM
  2. Mavic Speedcity Disc Wheel Set
    By SingleSpeedSlave in forum 29er Bikes
    Last Post: 06-02-2004, 08:41 PM
  3. Some questions on tubeless vs standard wheelset?
    By SLinBend in forum Wheels and Tires
    Last Post: 02-04-2004, 02:15 PM
