Geax saguaro TNT question- Mtbr.com
Results 1 to 3 of 3
    livin' the dream......
    Reputation: tjkm's Avatar
    Does TNT replace UST? I run the 29 UST on the front and need to replace it. I have DT Swiss wheels and the Stan's conversion kit. Can I run the TNT tubeless with this set uP? The UST version worked great, but can't find them.
    Thoughts?
    Former Bike Wrench
    UST indicates a tire that is completely air tight without the need for sealant. TNT uses a tubeless bead and a thicker casing than the standard tire, but requires sealant to be completely air tight. Since most people are already using sealant even with UST tires, using a tubeless ready tire like the Geax TNT saves weight but otherwise works tubeless perfectly with sealant.
    Thanks for your help. I might order a set of these since they lasted so long the first time.
