FSA QR rear hub: How do I remove the spindle?- Mtbr.com
Results 1 to 3 of 3
    Sep 2015
    Greetings,
    I have an old FSA xc-290 wheel set in great shape. I'm thinking about swapping out its 10-sp free hub with an 11-sp free hub. I want to do a dry run of removing the current free hub. However, I can't figure out how the f* to get the axle out. I've never had to tap an axle out before and don't want to start experimenting before I check in with people whose brains actually function.
    The two photos show the hub with end caps removed. They popped right off.
    Thanks for any tips or guidance you care to share!
    Attached Thumbnails Attached Thumbnails FSA QR rear hub: How do I remove the spindle?-img_20190511_144453429.jpg
    FSA QR rear hub: How do I remove the spindle?-img_20190511_144442401.jpg
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    If itís captured between two bearing like many of those wheelsets it gets tapped out.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Sep 2015
    Yep. A couple taps on the non-drive side loosened the axle and I pulled it out by hand.
    Thanks for the help!
  1. Next SL G4 83mm Spindle (will a sixc spindle work?)
    By coke in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-28-2018, 01:36 PM
  2. FSA hairline cracks around the spindle
    By gonzo in forum Singlespeed
    Last Post: 04-01-2017, 08:54 PM
  3. Sram XX1 BB30 Q Factor 168 - Short Spindle or Long Spindle?
    By Fastblack in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-12-2016, 03:29 AM
  4. FSA square taper carbon cranks and spindle length?
    By MTB Skippy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-10-2006, 06:28 AM
Members who have read this thread: 11
