Flow MK3 Durability?- Mtbr.com
Results 1 to 32 of 32
    Reputation: EatsDirt's Avatar
    Jan 2014
    In less then a half dozen rides I've managed to smash a Flow MK3... something I hadn't done in over two years on Flow EX. Bad luck... or new/lighter/wider isn't all it's cracked up to be? Anything better, stronger, stiffer at 30mm internal I should be looking at?
    Sep 2015
    A friend of my managed to cracked his crest (new version) 3 times. I stay away of the new line of that manufacture
    Verzonden vanaf mijn iPhone met Tapatalk
    I have a nice dent in my front making tire changes a real PIA. But then again i went over the bars.
    My rear spoke holes all have cracks but I don't take my tires off when truing the rims. They may have had too much tension from the begining. I have had them for 2 years though. \
    My I9's with MK3's are pretty light but next time I'll go for a heavier rim for sure.
    Reputation: LyNx's Avatar
    Well, let's see if we can do some investigating that my help us figure this out....Old FlowEX weighed about 520g-25mm wide, new FlowMK weighs about 520g-30mm wide The new rims are 5mm wider and actually weigh a bit less than the old ones AFAIR, so how could anyone trust they would be as strong
    You want strong and 30mm IW, try the WTB Asym i29 or STi29 for seriously strong, DT Swiss also has options, as does Spank and a few others.
    Quote Originally Posted by EatsDirt View Post
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Reputation: OwenM's Avatar
    Oct 2012
    You might try investigating the differences in material properties between their respective alloys before getting too full of yourself.
    They changed the alloy that they are using? If that's the case, then maybe, but I wasn't aware that they had. Either way, once upon a time when tubeless was now coming to be, Stans was basically the only name unless you went complete UST, but these days, SO many better options out there I don't even bother to look at them.
    Quote Originally Posted by OwenM View Post
    I can highly recommend the Spank alloy rim options. Awesome rims and mine have been very durable.
    Reputation: Rngspnr's Avatar
    Feb 2016
    The MK3's are garbage IMO. The old EX's had a triangular profile where the spokes entered the rim the new ones are flat giving less strength. Built a set for a buddy he cased a wall lip and completely bent the rim at impact point. The weld spot on the Stan's is finished like crap it actually makes the wheel hard to build and true. My personal favorite for aluminum rims is DT Swiss.
    2016 Evil Following V1
    2016 Dartmoor Primal+
    Reputation: Driverfound337's Avatar
    Killed a flows with neo hub so they sent me arch mk3, got 5 or 6 cracks around spoke holes on my arch mk3 after a year of use, Stans ain't what they used to be......They offered me rim replacement, I haven't gotten around to it yet, wish they'd just send me another wheel complete. Buuuuut the 3 times I have dealt with their warranty they have been good in the service department. I have run Stans for the last 5 years on various flows and neo hubs with good results but the next wheelset will be Christ King
    IMG_0452 by driverfound337, on Flickr
    They went from good old 6061 in the EX series to 6069 in the Mk3 series, not that it really makes much difference since their design & quality control is questionable. I have the same opinion as you, 10-15 years ago Stans was about the only tubeless choice other than full UST, but these days they're pretty much coasting on name recognition.
    These days I go DT or Spank for all my aluminum rims. Since you're denting rims, I'd recommend the DT EX511 since it's stronger though a bit heavier than the more popular EX481. With Spank, the Oozy Trail 345 fits the same role. Both the EX511 and Oozy 345 are very solid rims and significantly stronger than a Flow Mk3, not to mention much better quality. Spank & DT rims are dead straight out of the box whereas Stans rims will often have a noticeable kink or wobble at the seam.
    Jan 2014
    Good to hear my suspicions are confirmed. These MK3 didn't really build up all that well, and one rim strike pushed the whole rim up/over. I can't imagine a Flow EX doing the same thing and the rims had ZERO wall dents. Perhaps I'll give EX511 a shot.
    J:
    Reputation: Deerhill's Avatar
    Dec 2009
    Durable + stansmk3 = not to be used in same sentence
    Add me the disappointed mk3 user (tried a couple of these rims on my hardtails..on a symmetrical spaced hub/equal tension both sides), the new flat wide profiles= hops galore w/ the arches and flows..seams are also not as good as they used to be..wall thickness is just shaved waay down for weight weenies IMHO
    video=youtube;][/video]...
    Feb 2016
    Dt rims have a much better finish than Stans. There is no deviation radially or laterally at the weld point. They are also shot peened which helps increase strength. Don't know wheel size or what type of riding you do but I have XM481's on my FS an they have been bulletproof in the rocky terrain where I ride.
    Jan 2014
    FWIW, I contacted Stans who graciously offered me a crash replacement discount. Yea.... thanks but I'll pass.
    Quote Originally Posted by Rngspnr View Post
    DT rims are fantastic and I just built a road set for myself. The seam hop and/or tension imbalance is totally acceptable though.
    Human Crayon
    Reputation: sleestak's Avatar
    Quote Originally Posted by pulsepro View Post
    +1 After a lot of reading and talking to a few shops, I settled on Spank Oozy w/Hope Pro4 hubs, DT competition spokes and brass nipples. Good compromise between weight and strength and great bang for buck.
    Sent from my SM-G930P using Tapatalk
    ..:: sleestak ::..
    [SIZE] Matters [/SIZE]
    I wanted to check out the WTB KOM Tough I35's since they have the same ERD. Then I saw they were pinned instead of welded. Has anybody built up DT's or Spanks with the I9 straight pull spokes?
    Feb 2016
    Quote Originally Posted by One Pivot View Post
    Seam hop and imbalance? On DT rims? All the ones I've built have had no hop or imbalance. They build up as nice as carbon true and round.
    Replaced Arch EX rims with Arch MK3. So far a couple dents on the front rim.
    The Arch EX I had were 5 years old and went through 3 bike frames. The rear spoke holes started to show signs of cracks earlier this year, so I decided to replace them with wider new rims and went with Arch MK3. I've had many many rim strikes on the EX and they never dented. Rims were straight and round even after I unlaced them from the hub. I should have gone with another rim.
    Btw, these are 26"
    damn...making me regret Arch MK3. Only my front wheel so far and making me consider having the rear wheel made with another rim. Will look goofy with different rims front and rear but at least a front replacement/rebuild is cheaper than front and back.
    Jan 2014
    Quote Originally Posted by the-one1 View Post
    Right?! Either the new design sucks or the material they're using is soft as butter. When a somewhat minor wall strike pushes the whole rim flat and to the side something is wrong...
    Mar 2016
    I bought the new flow mk3 because Of stans old reputation. New rim has needed a fair bit of love to re-true over 2 seasons, and I managed to put a small hop in it over this summer (mostly my fault). Wouldn’t recommend them. Buddy has spanks that have been fair to him but he’s managed to thrash a few (2) so far (1 his fault, not sure the other one). I think we are going to try DT next, they have a strong presence and reputation online these days.
    Feb 2006
    DT SWISS EX511, my weight floats around 250-300lbs never had issues.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    WTB i29 Asym.
    mtbpete
    Reputation: changingleaf's Avatar
    I've seen the Flow MK3 hold up well with some riders, but they may not be hitting square edges at speed like some others. The DT Swiss and Race Face rims are my other go to alloy rims.
    Reputation: teK--'s Avatar
    Dec 2011
    I think they are too light/weak for how wide they are. The rimbed seems to be where they saved too much weight.
    I had some minor dings in the bead of mine, and then found several spokes were starting to pull through the rim (hairline cracks). Ended up replacing with the same rim to match the front wheel but started running a Cushcore insert and slightly less spoke tension.
    Team Blindspot
    Reputation: S-Works's Avatar
    Yeah, same thing happened to me. Previous Flows went 3 seasons without an ounce of problems, dented the MK3's on each of the first 2 rides. I am done with Stans, rebuilding with DT rims.
    Astigmatic Visionary
    Jan 2014
    From Pinkbike: "Rims we tested, including our own Flow MK3, struggled to handle the new drop. What was surprising was that our classic Flow EX (that skinny old rim with the triple cavity internal design) actually did quite well in this test"
    No surprise they had a redesign. I knew I wasn't crazy and the rims were feeble.
    Hey Stans, I'll try the new rim if you send me one for free instead of some half ass crash replace offer. If not, no worries as I'm having great luck with DT EX511's. -an ex EX lover
    Sep 2019
    The exact same thing happened to my Stans Flow MK3's. Cracked right at the spoke holes in about 9 different places. Happy to send pics to anyone that's interested.
    Oct 2019
    I am really happy with my MK3's that are handbuilt. I feel the durability is great but I do notice that I have to keep tightening spoke tension every 500 or so miles. When first built I got them to 5% standard deviation and right at the torque limit. I think they are great wheels but for someone more mechanically inclined and not a buy and forget type of wheel.
    Aug 2003
    Quote Originally Posted by sea_dude View Post
    The sooner you back them down to ~110kgf, the longer they'll last.
    Oct 2019
    Quote Originally Posted by mikesee View Post
    Ahh okay I always though getting closest to that number was best. Thank you!
  1. Sentry MK3 vs Baron MK3
    By Trojan366 in forum Wheels and Tires
    Last Post: 05-20-2018, 08:19 PM
  2. Doubt! Ztr Arch Mk3 or crest Mk3 for racing XC ?
    By 3olo in forum Wheels and Tires
    Last Post: 08-20-2017, 04:25 PM
  3. Replies: 4
    Last Post: 09-28-2016, 02:37 PM
  4. Replies: 2
    Last Post: 09-05-2016, 04:25 PM
  5. New Stan's Flow EX MK3 vs Easton ARC 30?
    By Whip Chop! in forum Wheels and Tires
    Last Post: 08-28-2016, 06:28 PM
Members who have read this thread: 35
