E*13 TRS Race/DT Swiss 240 wheelset and TRS tires - keep or swap out?- Mtbr.com
Results 1 to 6 of 6
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    I have a new bike on the way spec’ed with an E*13 TRS Race/DT Swiss 240 Wheelset and 2.35 TRS tires (Race front, + rear). I will need to decide very quickly whether I want to keep the wheelset and/or tires, or swap them out.
    185 lbs with gear, western Canadian Rockies terrain. On my previous bike I ran an Enve AM/DT Swiss 240 wheelset and a 2.5/2.35 DHF/DHR 2 combo.
    It seems to me that both the TRS wheelset and tires are on the heavy side. I have read in other threads how some love the grip of the tires. I haven’t come across too much about the wheelset.
    If anyone has any experience with the wheelset, your comments would be most appreciated, including any suggestions regarding alternatives. Same applies re the tires, although it appears that the long and short of it is that they are very grippy, and very heavy.
    I am looking to cut some weight possibly, provided I don't compromise too much in other areas.
    Thanks.
    Reputation: Legbacon's Avatar
    DT hubs are very reliable, the tires are great, and I don't know anything about the rims.
    Formerly Travis Bickle
    Team Robot. "modulation is code for “I suck at brake control.” Here’s a free tip: get better."
    Mar 2015
    Quote Originally Posted by Travis Bickle View Post
    Thanks. I did a bit more searching and reading. Looks like the wheelset and tires will be heavy, but good to excellent in all other respects. The lifetime warranty on the rims will encourage me to ramp things up even more on the trail, at nice low pressures.
    Apart from converting it to tubeless and changing the grips and saddle, it looks like this will be the first bike in the the last 6 or more that I will not be screwing around with when it arrives at the LBS, swapping this and that.
    Pretty much good to go.
    I demoed a Wreckoning with the E13 tires and it rolled on par with Minion DHR/F, which is good enough for me.
    Oct 2015
    The tires will be like running a DHR2 3c front 2c in the back.
    Mar 2015
    Quote Originally Posted by Cerberus75 View Post
    Excellent. Given that I have been running a DHF/DHR 2 combo for the past several years, this should be great. Certainly good enough to give them a shot and not swap them out at the front end.
    Totally stoked. My soon-to-arrive bike will remain pretty much stock spec.
    Thanks guys. Much appreciated.
  1. Enve m50 29” wheelset with DT Swiss 240
    By se7en34 in forum Classifieds
    Last Post: 10-09-2017, 03:28 PM
  2. DT Swiss 240 / Hugi 240 -- 20 mm?
    By Lithified in forum Wheels and Tires
    Last Post: 02-12-2013, 08:54 AM
  3. How to swap bearings in Rear Dt Swiss 240 Hub?
    By gigabyte772 in forum General Discussion
    Last Post: 08-19-2012, 09:08 PM
  4. DT SWISS M 520 rim with DT Swiss 240 hub
    By freezombi in forum 29er Bikes
    Last Post: 05-25-2012, 12:40 PM
  5. DT SWISS M 520 rim with DT Swiss 240 hub
    By freezombi in forum 29er Components
    Last Post: 05-25-2012, 08:12 AM
