DT XM481 vs RF Offset Arc 30 vs WTB ASYM i29- Mtbr.com
    Reputation: oldsklrdr's Avatar
    May 2012
    Doing custom wheel build and interested in alloy rims, not going carbon...
    Narrowed down to the following in order of weight lightest to heaviest:
    Raceface Arc Offset 30
    DT XM481
    WTB ASYM i29
    Any pro’s and cons i should be aware of?
    Or all relatively the same?
    Was leaning toward the arcs...
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    I've heard that depending on what rubber you plan on using some beads don't work as well with WTB. That is purely anecdotal however - and others should chime in. I do know that tires I like to use, Maxxis and Spec, work well on DT rims.
    I have built one DT 481 front wheel (27.5, 28H, DT 240 straight pull hub, DT double butted spokes and alloy nips). Over 600 miles on it so far. No problems. Like the width: Inner 30mm outer 35mm. I ride mostly cross country and epic(long) rides with a little bit of fun races added for flavor.
    urmb
    “How inappropriate to call this planet "Earth," when it is clearly "Ocean.”
    ― Arthur C. Clarke
    Jun 2017
    I have a set of the ARC offsets in order. Will update after a few rides. Someday hopefully soon.
  1. WTB Asym i29 VS KOM Tough i29 ?
    By guim in forum Wheels and Tires
    Last Post: 2 Days Ago, 06:47 PM
  2. Spoke length for WTB Asym i29 Rims
    By snoopy20 in forum Wheels and Tires
    Last Post: 08-24-2017, 04:39 PM
  3. optimal tire width to WTB asym i29?
    By Amit Ifrach in forum Wheels and Tires
    Last Post: 11-15-2016, 01:50 PM
  4. Stans flow mk3 or wtb asym i29
    By kikoraa in forum Wheels and Tires
    Last Post: 10-28-2016, 11:37 PM
  5. DT XM481 vs WTB ASYM 129 vs Easton Arc vs Stans Flow MK3
    By olibluegoat in forum Wheels and Tires
    Last Post: 07-12-2016, 05:40 AM
Members who have read this thread: 9
