dt xm 421 vs wtb kom light- Mtbr.com
Results 1 to 5 of 5
    Hi
    I plan to build new wheelset for cross country and single tracks, not very technical and no jumping.
    My weight is ~80k
    Using shimano M8110 boost hub
    I look at 29" 32H 'dt swiss xm 421' and 'wtb kom light i25'
    Which one is more recommended ?
    Feb 2005
    I have wider rims of both brands the DT Swiss XM481 has lasted the longest and Ive abused them and run 29x2.3 tires. Im 73K but I ride a lot and look for jumps and drops. I have the WTB Asym35 too. Theyre strong too but wider and have 29x2.5 tires or bigger that probably protects the rim a little.
    Seven Sola fully rigid MTN SS
    #1⚙️All year
    Seven Evergreen gravel grinder
    #ride4lifefit4life
    Esker Hayduke hardtail
    I went back and forth between a DT Swiss XM421 and WTB KOM. Went w/ DT Swiss as I read the KOM could possibly dent easier.
    If you are XC riding take a look @ the DT XR391 - same inner width as the rims you have mentioned.
    Thanks,
    I saw the 391, the difference is around 25 grams. The question is whether this is worth because the 421 max rider weight is 120 vs 110
    Quote Originally Posted by higuygonen View Post
    Thanks,
    I don't think i'd factor in the max rider weight into the equation as your weight doesn't come close.
    The XM is probably a stronger rim but it really depends on how you ride. I am not sure the XM421 weighs as advertised. My Apline scale weighed the XM a little over 25g heavier.
  1. XM 421 Good Enough for 140# rider?
    By rnm410 in forum Wheels and Tires
    Last Post: 02-25-2019, 10:25 AM
  2. DT Swiss XM 421 or EX 471 for Heavier Rider and Bikepacking
    By jfdougherty in forum Wheels and Tires
    Last Post: 12-03-2018, 05:37 AM
  3. DT Swiss XM 421 vs. Stan's' MK3 Arch rim?
    By keen in forum Wheels and Tires
    Last Post: 05-16-2018, 06:19 PM
  4. Anyone running a Stan's Arch MK3 (DT XM 421)?
    By keen in forum 29er Components
    Last Post: 01-15-2017, 11:01 AM
  5. WTB i23 KOM strength? Any i23 KOM user reviews?
    By FREAKAH in forum Wheels and Tires
    Last Post: 06-10-2015, 10:01 PM
Members who have read this thread: 36
