Results 1 to 3 of 3
    Dt Swiss hub replacement from boost to non-boost
    Quick question- I have a spare boost wheelset that I want to use for a project. The front wheel has a DT Swiss 350 boost hub however the fork I want to use is non-boost. Iím thinking of switching the hub to a 350 non-boost to fit the fork while trying to retain the spokes and rim. My question is, can I re-use the spokes or will I need to get longer spokes?
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Your spokes will need to be 1mm shorter. It will probably work.
    That 1mm difference should be able to be taken up in the nipples, right?
  1. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  2. Boost to non-boost for SRAM 716 15x110 front hub?
    By Doug in forum Wheels and Tires
    Last Post: 10-12-2017, 05:18 PM
  3. Non Boost cranks on Ripley LS with boost
    By marcus_dukakis in forum Ibis
    Last Post: 09-27-2017, 10:56 AM
  4. Boost crankset with non boost rear hub?
    By 2AllBeef in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2017, 03:14 PM
  5. Boost or non-boost fork for 5010v2?
    By furball in forum Santa Cruz
    Last Post: 02-03-2016, 09:10 PM
Members who have read this thread: 26
© Copyright 2018 VerticalScope Inc. All rights reserved.
