Results 1 to 5 of 5
    Reputation: kRyP70n173's Avatar
    Mar 2011
    DT Swiss EX 511/XM 481 vs Syntace w33i (29" rims)
    Hello, I'm looking for some advice with buying new rims. I have Hope Pro4 hubs, 28h both rear and front and would lace the wheels with sapim CX Ray spokes.
    My plan was to get DT Swiss EX 511 rim for rear wheel and XM 481 for front wheel and my other option is Syntace w33i front and rear.
    Syntace is the same weight as EX 511, 570g per rim while XM 481 is 520g per rim.
    I have 90kg (200lbs) and mostly ride all mountain or enduro and for some strange reason I enjoy long climbs.
    Any advice welcome
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    You aren't going to find many who have experience with the Syntace stuff. I posted a thread about their hubs and I was the only one who had ever touched a pair.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    They make good stuff but aren't that known.
    I think the only contact with theirs stuff most people had, was with the X12 142*12mm rear axles they developed.
    I'm planning on build a new set of wheels with the new Shimano hubs and the W33i rims, but only when affordable cassettes became available.
    The W33i being 28 holes only, means I have to get new hubs, other wise I would already had built a wheelset with them.
    Your DT option also seems pretty solid, don't think you can go wrong with either of them.
    The Syntace is 33 inner vs 30 for the XM. The 33 would get you more footprint at lower pressure from some tires. So it depends on what tire you need for your terrain. If you lose tires from sidewall cuts and have to run a thicker heavier sidewall tire wider may not be as usable as it would be with a 120tpi lighter more flexible sidewall tire. 2.3 tires match with these rims. 2.5 or 2.6 at higher pressures for enduro speeds and terrain.
    Laser spokes are the equivalent strength and weight of CX Rays just a lot less expensive.
    Mar 2011
    Thanks for all info. I decided to go with DT Swiss combo, they are 40 cheaper per rim, 30mm is enough for my needs and judging by all reviews the ride quality/responsiveness is great.
  1. DT Swiss shootout: XM 481 rims w/350 hubs vs XM 1501 Spline
    By stepping-razor in forum Wheels and Tires
    Last Post: 06-27-2018, 05:38 PM
  2. DT Swiss EX 511 28H vs XM 481 32H Front wheel build suggestion?
    By maclgallant in forum Wheels and Tires
    Last Post: 11-06-2017, 03:51 PM
  3. differences between dt swiss EX 471 and XM 481
    By useport80 in forum Wheels and Tires
    Last Post: 08-16-2016, 03:23 PM
  4. Syntace F139 + Syntace EC70 Monkeylite
    By xbiker in forum General Discussion
    Last Post: 03-10-2008, 02:45 PM
  5. Syntace F99 w/ Syntace Duralite Carbon?
    By Cheers! in forum Weight Weenies
    Last Post: 01-08-2007, 12:24 PM
Members who have read this thread: 47
