Results 1 to 12 of 12
    Coffee Drinker
    Reputation: Taildragger's Avatar
    Mar 2005
    DT Swiss 370 to star ratchet
    e=mtb2
    Reputation: levity's Avatar
    Oct 2011
    Good one, thank you!
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    I got a deal on some Syncros hubs with the DT 370 system. I put the star ratchet pieces together about a month ago but the seal on the freehub body didn't line up very well. This was a mountain freehub so maybe the 11 speed road is longer and fits better.
    Is that like $250 bucks worth of parts and tools to convert your $50 hub into a $150 hub?
    Reputation: 006_007's Avatar
    Quote Originally Posted by One Pivot View Post
    yabbut the satisfaction of doing it has got to be worth at least 200-250 bucks.......
    Reputation: boomn's Avatar
    Definitely don't buy a 370 hub with the hope of doing this upgrade!
    But the 370 is generally only found in complete wheelsets, and is pretty common as a stock hub. So this could be cheaper than replacing an entire wheel to upgrade. Even then, the math probably only works out if your bike shop already has one or both of the tools
    mbtr member
    Reputation: scottzg's Avatar
    Not to mention dt370s are a pretty decent hub. I'd happily run a 370 if i owned another one. I tend to kill hubs, and mine worked great.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    + $40 for spokes, $12 Nipples, $40-50 labor to lace a new hub into a wheel.
    Bicycles donít have motors or batteries.
    Ebikes are not bicycles
    Coffee Drinker
    Mar 2005
    Well, I did the conversion today. Exactly as shown with the exception of staying with an XD driver. The most demanding part was removing the drive ring, very much like removing a freewheel. A well secured vice is recommended. I didn't buy the tool to install the star ratchet drive ring, just hand snugged it. It will tighten itself. The engagement is noticeably 'tighter/closer'. What should I call this? A DT-360?
    Quote Originally Posted by Taildragger View Post
    How was the seal on the XD driver?
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by newportl View Post
    What do you mean, "how was the seal..."?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Coffee Drinker
    Mar 2005
    The seal from the 3 pawl XD driver transferred directly to the star ratchet XD driver.
  1. DT Swiss 3 Pawl 370 Hub convertible to Star Ratchet
    By RiderofPA in forum Wheels and Tires
    Last Post: 1 Day Ago, 11:40 AM
  2. Star ratchet / ring nut Bontrager Race Lite hub (DtSwiss 370?)
    By kmjelle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-06-2017, 07:27 PM
  3. DT swiss 36 star ratchet upgrade Pros and Cons
    By Ace5high in forum Wheels and Tires
    Last Post: 07-02-2013, 08:06 AM
  4. DT Swiss 240s Star Ratchet
    By reamer41 in forum Wheels and Tires
    Last Post: 10-29-2012, 10:19 PM
  5. DT Swiss Star Ratchet
    By Hikers Only in forum Wheels and Tires
    Last Post: 10-27-2012, 10:08 AM
Members who have read this thread: 123
