does the inner tube size have to be the same as the tire?- Mtbr.com
Results 1 to 6 of 6
    Reputation: ussprinceton2004's Avatar
    I have a set of Forte City ST 26x1.5 tires and would like to put them on to my new wheelset for road use only. Is it ok to use larger sized inner tubes marked as 26x1.95-2.125 I have laying around? By doing a mock up by placing the larger inner tubes around the tire, it seems to fit well. Is there anything wrong with using larger sized tubes such as the 26x1.95-2.125 tubes on smaller sized tires like the 26x1.5?
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Should work fine, just be a bit heavier.
    I go the other way, use 2.8 tubes in 4" tires no prob.
    Fat-tired Roadie
    Nov 2007
    Sometimes it's hard to get larger-sized tubes to sit right in smaller-sized tires. Sometimes it's easier to pinch the tube between the tire and the bead.
    If you've already got 'em, though, give it a shot. Put a little air in the tube before you try to install it - it makes it behave better. If that makes it bigger than the tire, well, there's your answer.
    My bikes have bigger sized tubes in the tires, rather than matched sizes. Seems to reduce pinch flats since the tube isn't stretched nearly as much as with the "proper" sized tube. Thorns don't cause a sudden flat either, I usually find a flat tire the next day rather than during the ride.
    '01 Schwinn HG Comp - '12 Giant Defy 1 - '14 Kona JtS - '18 Rocky Mtn Altitude A30 - '19 Scott Spark RC Team
    Bicyclochondriac.
    Quote Originally Posted by AndrwSwitch View Post
    This has been my experience.
    I'd rather have an under-sized tube than an over-sized one.
    Never trust a fart
    Reputation: frdfandc's Avatar
    I ran into this at work yesterday. A larger tube shoved into a smaller tire. I tried for 10 minutes trying to get the customers old tube to fit a new tire. Ended up replacing the tube as well.
  1. 700x37 tire size what tube size?
    By noobie39 in forum Wheels and Tires
    Last Post: 07-11-2011, 04:01 PM
  2. Tire size vs tube size
    By cstallings in forum Beginner's Corner
    Last Post: 07-02-2010, 11:24 AM
  3. Tube with different size tire
    By Dictatorsaurus in forum Wheels and Tires
    Last Post: 12-19-2009, 05:50 PM
  4. matching tube size to tire size
    By FireDog46 in forum Wheels and Tires
    Last Post: 05-07-2007, 10:26 AM
  5. Tube size versus Tire Size
    By Krap Foo in forum Wheels and Tires
    Last Post: 09-30-2004, 10:21 PM
Members who have read this thread: 4
