Do the spacers on the front wheel come off?- Mtbr.com
Results 1 to 15 of 15
    Reputation: JimF777's Avatar
    Sep 2018
    I noticed the other day that it sounded like there was some gritty, grinding, or rubbing sound from the front axle. I I pulled the wheel and only thing I noticed was when I turned the spacer looking tube on the outer sides, I could feel a bit of dirt in there. They didn't seem to want to come out easily and I was't going to force it. On the motorcycle, those damn things are a b!tch to get to stay in place when the axle is out. I sprayed a bit of WD40 in there and no more grittiness but...
    So do they come out or are they meant to?
    Just one more ride away from a good mood
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Donít spray WD40 on anything on an MTB unless you are trying to clean out a bearing and re-pack it with grease.
    Also, post a picture.
    Death from Below.
    Aug 2018
    Are you talking about the axle end caps?
    And are you saying that there was dirt in the area where the axle would pass through the hub? Or are you saying that the grit is between the end cap and the rest of the hub?
    Or is the gritty noise coming from the hub bearings itself?
    Also, was the noise potentially rotor noise?
    Sep 2018
    Quote Originally Posted by ocnLogan View Post
    I just pulled the axle for a couple pics and there's no dirt or grit on the axle, so that's good. Must be the end caps and hub?
    Here are the two pieces I'm inquiring about.
    Do the spacers on the front wheel come off?-img_20200212_061928.jpgDo the spacers on the front wheel come off?-img_20200212_061940.jpg
    Sent from my Pixel 3 XL using Tapatalk
    West Chester, PA
    Quote Originally Posted by JimF777 View Post
ID:	1311321Click image for larger version.
    Yes, they come out. If I recall correctly that hubs end caps are 2 piece, the "tube" and the outer ring that snaps in and holds them. You may have to use a pair of pliers to wiggle them off. If you're worried about scratches use a piece of inner tube to cover the plier teeth
    Sep 2019
    Just push in the tip of your axle and lever them off.
    Jan 2009
    You sprayed WD-40 into a HUB? It's going to get in the bearings and trash them. If you think your hub sounded gritty before, wait until that water displacement fluid does it's hub and completely washes the grease out of your bearings. You're going to need pull the hub apart and replace them bearings some time soon
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    ^depends on the amount of wd-40, but if it got in the bearings, yes they are done.
    wheel bearings and wd-40, not a mtb but close enuf....racing motorcycle, got some nasty tar snake wrapped up around swingarm and rear sprocket, used wd-40 to loosen and remove tar snake. I did not pay enough attention to a wd-40 drip that went to rear axle. didn't blast the axle just a drip of wd-40 got in there. did 5 practice laps, fine. did qualifier 3 laps, fine. did one lap of race, by corner 3 on lap 2 my rear wheel bearing seized, destroyed it, had to have recovery tow truck vehicle lift up bike and hook me back to pits. from one small dab of wd-40 on a bearing. so yeah wd-40 is not really nice to grease, it turns grease to sh*t.
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by wheel builder View Post
Name:	DT 350 end caps.jpg
    Hey, that's pretty good idea. Where did you get that photo?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Sep 2018
    That doesn't jack up the axle threads?
    Sep 2018
    Well the WD40 posts had me worried, and thanks to the axle pry-bar idea, I was able to get the spacers off and take a look underneath. Thankfully, there was still a good layer of grease under the spacers, but I added some more anyway, and cleaned the spacers as well as the snap in rings.
    I was then stuck trying to figure out how to get them back in, but thankfully, a socket fit nicely over the spacer and on the ring and was able to gently tap it down evenly.
    since 4/10/2009
    Reputation: Harold's Avatar
    I've always gone the other way with problematic end caps. Use the axle to push them out from the back side.
    Just packing more grease in there won't really address the fact that WD40 got in in the first place. Take a rag and wipe the old, contaminated grease out before putting new grease on top of the contaminated stuff. Bonus points if you use isopropyl alcohol to make sure you got any extraneous WD40 residue from outside. Should be no need to get that fancy to push the endcaps back on. I have always just pushed them on by hand.
    Magically Delicious
    The thru axle works great and you wont jack up the threads because it comes off quite easy. Just don't insert thru axle past cap depth and into the inner bearing.
    Sep 2018
    The caps just sit against the bearing, the thin ring is what is a "press fit" in the hub. Way too tight for a fingernail to press in. I'll feed it some alcohol today ;-)
    Reputation: Lone Rager's Avatar
    Dec 2013
    I think you guys are going a little nuts on the WD40. It's just light lube with solvent. The solvent will evaporate. Unless you do something weird, very little will get past the bearings seals and the little that does will have no effect.
    Now if you spray water and aqueous based cleaner/degreaser and that gets in your bearings, then you have something to worry about.
    Do the math.
  1. Replies: 3
    Last Post: 08-29-2019, 08:48 AM
  2. Replies: 2
    Last Post: 03-07-2019, 05:00 AM
  3. SS cassette Spacers - need thinner spacers
    By ncj01 in forum Singlespeed
    Last Post: 07-21-2011, 08:23 AM
  4. Front Lefty Wheel Wont Come Off !!!!
    By ziscwg in forum Cannondale
    Last Post: 06-23-2008, 09:08 PM
Members who have read this thread: 68
