Different wheelsets for different tires- Mtbr.com
    Does anyone here have different wheelsets for different types/widths of tires? Is it necessary to have a set of disc brake rotors for each set, or is it easy to just swap them out? What about the cassette? Thanks!
    Class Clown
    Reputation: dundundata's Avatar
    i will eventually. it's not difficult to swap rotors/cassette but it does take a little time.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I like wide tires for dirt, so stick to the same rims...
    But If I were swapping wheels, I'd have at least brake rotors for each wheel. Swapping 6-bolt rotors would be a bit much. The Shimano system might be an easier swap.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Thanks for the replies. I do have a center lock disc brake rotor in my current setup, which i thought may make the swap easier. Not sure about the cassette, but sounds like that shouldn't be too difficult either. I also want to be able to go to a wider tire but currently have an xm719 which has a max spec of 2.3 for tire width.
  1. SPAM: Snowbike wheelsets and tires
    By surlymonkey in forum Fat bikes
    Last Post: 10-12-2010, 08:28 PM
  2. Weight of VRC wheelsets, tires, Weenie-not...
    By deadmanschest in forum Vintage, Retro, Classic
    Last Post: 08-07-2007, 03:45 PM
  3. should I swap tires between my two wheelsets?
    By sac02 in forum Wheels and Tires
    Last Post: 05-01-2006, 01:22 PM
  4. cyclocross wheelsets OK with bigger tires?
    By SS4life in forum 29er Bikes
    Last Post: 12-14-2005, 02:26 PM
  5. SPAM 29’er Disk Wheelsets and Tires
    By 29Inches in forum 29er Bikes
    Last Post: 06-11-2005, 03:04 PM
