Results 1 to 11 of 11
    Dec 2014
    Desparately seeking Boost hubs 24 holes - virtually impossible to find
    I have a fairly new Enve M525 wheelset laced with DT Swiss 240 Standard hubs (not boost). .
    I really like These wheels but my new bike has boost spacing.
    So I am looking to just replace my standard hubs with boost hubs preferably DT Swiss as well.
    However, it has been impossible to find boost hubs, centerlock with 24 holes.
    I would appreciate any leads.
    Ebike Evangelist!!
    adapter kit w/ shimz. Save money ride your current wheels.
    https://www.amazon.com/Boostinator-A.../dp/B01AR8TTNI
    Unfortunately, it seems the centerlock cannot be shimmed out 6mm for the rear wheel, so a partial solution.
    Industry nine trail 270 hubs are 24h, but six bolt not centerlock. I would try to find 6 bolt variants of the hubs you have now and relace and use shimz. Maybe you can sell your current hubs to offset the cost.
    Good luck.
    Dec 2014
    I considered those Adapter kits but its not that simple. All my Rotors are centerlocks so I don't really want to invest in new Rotors. Moreover, the wheels have to be redished after installing those Adapters.
    So I am still looking.
    Apr 2005
    dt makes a 240 boost cl hub for enve's complete wheel builds....they were supposedly going to start offering them aftermarket. contact enve they might re lace yours up with hubs they have.
    since 4/10/2009
    Reputation: Harold's Avatar
    You bought wheels with ENVE rims and you're complaining about having to buy a couple 6 bolt rotors?
    And not willing to redish existing wheels?
    Reputation: boomn's Avatar
    Quote Originally Posted by paxfobiscum View Post
    Redishing is not needed with all adapters. That depends on how much length they added to the left end cap vs the right.
    Also, some adapters that require redishing actually eliminate the need for shimming the brake rotor altogether
    MRP has produced offset brake mount adapters that eliminate the need shim the rotor and therefore can work with centerlock wheels. I haven't seen them for sale separately but I would contact them for more info
    Also, some adapters that require redishing actually eliminate the need for shimming the brake rotor altogether.
    Dec 2014
    Quote Originally Posted by Harold View Post
    Yes on some Points, except the complaining part. I am not complaining about anything.
    I bought the wheels really cheap used but I did not know they were standard (non boost) DT swiss hubs. But I plan to use these hubs to build a wheelset for my road bike anyway.
    I assumed that it was easy to find a replacement DT Swiss Boost 24 hole. Unfortunately, I could only find 28 or 32 hole DT Swiss boost hubs and that 24 hole is quite rare - even with 6-bolt Rotors.
    Been using DT swiss hubs for a decade and intend to stick with them. Heard good things about I9s but I frankly prefer DT swiss for a lot of reasons.
    I found a good source this morning. FYI.
    Call DT and or Enve tell them you have enve 525 rims and you NEED not want NEED hubs.
    Dec 2014
    I contacted Dt Swiss (Europe) and within an hour thwri US rep emailed me. No dice. Those hubs are not sold retail and only come with built Enve wheels. So I emailed Enve. Lets see what they say.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Onyx would probably be happy to drill some 24h shells for you.
    mtbpete
    Reputation: changingleaf's Avatar
    I agree, Onyx would be a good place to check.
  1. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  2. Replies: 6
    Last Post: 07-24-2007, 05:48 PM
  3. NEEDED (desparately!!): AMP STUFF!!!
    By LardLover in forum Vintage, Retro, Classic
    Last Post: 04-16-2005, 12:09 PM
  4. desparately need help with Yakima Roc hitch bike rack
    By guppie in forum General Discussion
    Last Post: 03-04-2005, 08:26 PM
  5. Desparately seeking hub adapters!
    By Lynn in forum SRAM
    Last Post: 06-17-2004, 09:38 AM
Members who have read this thread: 57
