Cushcore loosing air from the side- Mtbr.com
Results 1 to 2 of 2
    Was on a ride, hit hard and even felt the wheel touching the rocks, from then on, it started to loose air from the side.
    Any ideas how to fix this?
    Oct 2018
    Quote Originally Posted by motoadve View Post
    Probably need to replace the tire that now has a hole in it (pinch flat).
    That's my thought.
    Next up is a damaged rim.
    To test, spray the bead with water and look for a leak. Mark the position on the rim and the tire.
    Break the bead loose and rotate the tire on the rim. Reinflate.
    Spray bead with water. Is the leaky spot where the tire is marked or is the leaky spot at same place on the rim.
    If it's on the rim, the rim is bent. Likely, the leak has followed the tire though and you now have a tear in the tire.
  1. RS-1 damper side 120mm, air spring side 100mm
    By Marc_Encinitas in forum Shocks and Suspension
    Last Post: 05-03-2018, 11:24 AM
  2. Revelation WC Loosing Air
    By Martin6 in forum Shocks and Suspension
    Last Post: 10-10-2011, 11:08 AM
  3. thorns and stans, still loosing air, time for tires?
    By madsedan in forum Wheels and Tires
    Last Post: 10-03-2011, 07:53 AM
  4. Crossmax sl ust-loosing air via spokes?
    By Colin D Shots in forum Cannondale
    Last Post: 03-31-2011, 02:52 PM
  5. Loosing weight (Rider), without loosing strength
    By Festusjrf in forum Weight Weenies
    Last Post: 12-03-2007, 10:25 PM
Members who have read this thread: 28
