Results 1 to 7 of 7
    Currently 27i rim, is there a whole new world of traction at 30 to 35 mm?
    Maybe it's upgrade-itis, but I'm thinking of a new front 29er carbon rim for my 130mm - 140mm trail bike. Rider 160 pounds, not a lot of rocks. Ride comfort not the goal, just lots more front end traction for aggressive high speed cornering.
    Currently on 27i hookless rims running 2.35 and 2.4 tires usually 21 to 23 psi depending on trail. Speeds are high and aggressive. I'm sensitive to sidewall flex but that's probably more tpi, psi and profile?
    Demo'd bikes with 30i rims with the likes of HR2 2.35. If I go wider maybe a non-piggy 2.6 or Maxxis WT which will probably be a true 2.4?
    I don't want a lateral move from 27i so I presume a 30i is redundant. Or is it? Is there a sweet spot at 33-35mm? Splitting hairs, I know, but if there's a "whoa, that's much better" width then I'd make the leap.
    Or just save my time and money running 27i as an all-arounder for my weight and trails?
    No Clue Crew
    Apr 2005
    Save your money.
    Just like a raindrop, I was born to fall.
    Aug 2015
    Its best to build up a set and try it. Ive found a noticeable difference going to 34mm iw in terms of traction and comfort.1
    Sent from my SM-G930V using Tapatalk
    Reputation: wooly88's Avatar
    Subscribed. Iíve got the same question myself.
    Aug 2015
    I may be putting up some 650b carbonbicycle 34iw 420g rims on pb soon. Good way to try it if you know how to build up a wheel. Many high end trail and enduro bikes come with wider rims these days. The tire selection is much better today than a few years ago.
    The answer is a set of Michelin Wild Rock'r2 tires. That will do more for front end cornering grip than pretty much anything else you can buy for your bike.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Depends on the tire.
  1. Replies: 4
    Last Post: 01-06-2018, 08:46 PM
  2. When is more traction, too much traction?
    By singletrackmack in forum General Discussion
    Last Post: 05-15-2017, 05:21 AM
  3. New wheels thinner rim = tire flex, less traction?
    By the.rebot in forum Wheels and Tires
    Last Post: 08-12-2011, 08:06 PM
  4. A Whole New World
    By Olyoyster in forum Niner Bikes
    Last Post: 03-28-2011, 05:53 PM
  5. Is there any jensonusa coupon/ discount currently available?
    By crisillo in forum Where are the Best Deals?
    Last Post: 08-29-2004, 10:17 AM
Members who have read this thread: 51
© Copyright 2018 VerticalScope Inc. All rights reserved.
