Cracked Roval Control SL Rear Wheel - Options?- Mtbr.com
Results 1 to 7 of 7
    Cracked Roval Control SL Rear Wheel - Options?-screen-shot-2019-10-09-3.22.59-pm.jpg
    I'm not sure when this happened but just swapped my rear tire and realized I have a substantial crack in my rim. It was holding air but I'm a bit confused on how the tire survived the impact. I was running an Aspen 2.25 with about 25psi. Wheel is only slightly out of true
    Any suggestions on what to do?
    I don't think crash replacement will apply since I'm not the original owner and also don't have the receipt.
    Can I rebuild the wheel with another rim? Is the Roval hub compatible with non Roval wheels? Any suggestions on a good carbon rim?
    Can it be repaired?
    Or should I just look for a new wheel?
    Quote Originally Posted by turquoise View Post
Name:	Screen Shot 2019-10-09 at 3.22.59 PM.jpg
    Can it be repaired?
    Yes you should be able to replace rim, but unless lucky and dimension same,youll prob have to replace spokes too. If its a good hub,might beworth it, but otherwise might not, esp if you have to pay labor too
    It's a roval branded dt 240
    Reputation: Millennial29erGuy's Avatar
    Feb 2017
    Rebuild it with either the same roval rim from a specialized dealer (ask them for a crash replacement deal, the worst they can say is no), or a santa cruz reserve rim, or a dt swiss aluminum rim.
    Yes the hub is worth reusing IMO.
    My name is George. Iím unemployed and I live with my parents.
    2017 BMC Speedfox 25-622 ISO
    2017 Salsa Timberjack 40-584 ISO
    mtbpete
    Reputation: changingleaf's Avatar
    The hub is definitely worth reusing.
    To follow up on this.. bike shop sent it back to specialized for a rebuild. new spokes and rim for about the cost of a carbon hoop. Overall very satisfied. For some reason specialized didn't put on tubeless tape. What comes on rovals stock is not tape but a rim strip. The bike shop didn't want to reuse that and recommended they tape it with whisky tape. The rim strip looked fine but maybe it's a one time use
    Sep 2019
    If there was a tubeless tape on the rim it is definitely for one time use. Ask the guys in your bike shop to put on a new tape.
  1. Replies: 2
    Last Post: 08-01-2016, 03:58 PM
  2. Roval Control Carbon or Control Carbon SL?
    By CHSAD in forum Specialized
    Last Post: 11-02-2015, 03:07 AM
  3. Replies: 3
    Last Post: 08-18-2014, 11:57 AM
  4. Roval control SL wheel set vs crossmax SLR wheel set?
    By Yellowr6 in forum Wheels and Tires
    Last Post: 08-18-2014, 06:37 AM
  5. Roval Control SL vs Roval Control SL 142+ 29
    By jscot111 in forum Specialized
    Last Post: 12-13-2012, 07:53 AM
