Converting DT Swiss OS28 to 15x100?- Mtbr.com
Results 1 to 3 of 3
    Back at it
    Reputation: storz's Avatar
    Jan 2011
    Howdy.
    Is it possible to convert my Specialized DT Swiss OS28 front hub to a 15x100 (non boost) to accept a wider range of forks?
    I am currently running a 100mm 2012 Fox Float 29 and would love to run 120mm fork but the options seem limited to non-existent with 9mm QR drop outs
    This is the hub in question
    Converting DT Swiss OS28 to 15x100?-1100866d1476910834-axle-standards-explained-dt-swiss-01.jpg
    Ellsworth Evolve SST.2
    mtbpete
    Reputation: changingleaf's Avatar
    If specialized doesn't have kit to reconfigure that hub, which I doubt they do then you would have to manufacture something yourself. So basically, no.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Check this website: https://wheelbuilder.com/dt-swiss-hub-conversion-kits/
    That may be specialized branded hub but im going to guess the internals are standard DT swiss. Have you tried popping the caps off? ..They have a lot of kits available..worth a try......
  1. WTB: DT Swiss 350 15x100 front hub 32H
    By RS VR6 in forum Classifieds
    Last Post: 03-26-2019, 08:37 PM
  2. Replies: 1
    Last Post: 11-21-2018, 08:36 AM
  3. DT Swiss 240: Convert 15x100 Front to Boost?
    By smmokan in forum Wheels and Tires
    Last Post: 07-19-2017, 09:14 PM
  4. Question about converting hubs and Spec's OS28 end caps...
    By madsedan in forum Wheels and Tires
    Last Post: 06-21-2011, 05:54 PM
Members who have read this thread: 13
