Convert asymmetric rim to tubeless - which kit- Mtbr.com
Results 1 to 6 of 6
    I would like to convert this rim to tubeless. Which kit would you recommend for this? Would the Orange Seal Tubeless kit worj and should I choose 24 or 18 mm?
    Link to rim: https://www.lightbicycle.com/EN928-a...tain-rims.html
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Same kit as you would use in a rim that's not asymmetric.
    Any tape that's between 25mm and 30mm should work, personally I would go with a tape that would reach the walls that would make a better seal and when removing the tires the probability of damaging the tape setup would be lower.
    Reputation: LyNx's Avatar
    Your link goes to a rim that is 28mm wide internally, so you want tape that is 34mm wide to go bead to bead so the tyre forms a seal with the tape and not the rim/tape, as there's possibilities of leaks, damaging the tape when removing the tyre, etc. Loads of info here on setting up tubeless.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    mtbpete
    Reputation: changingleaf's Avatar
    I agree with the others, wider tape for the most successful and trouble free tubeless setup.
    I've converted my BTLOS 30mm inner using this
    Tape 33mm:
    https://www.ebay.com/itm/Hold-Fast-T...m/253950254676
    Sealant:
    https://www.ebay.com/itm/500ml-17-oz...e/260938651318
    and some DT Swiss tubless valves with removable core.
    I mounted the tires initially w/o sealant, and they actually kept the pressure for 2 days (dropped from 30 psi to 27psi). Added 60ml sealant for a 29" 2.5 Minion and a 2.3 Aggressor. Holds the air very well.
    Thanks all :-)
  1. Replies: 8
    Last Post: 09-11-2017, 08:33 AM
  2. Replies: 1
    Last Post: 02-21-2016, 04:03 AM
  3. Asymmetric hookless carbon rim for 29er
    By bktide in forum 29er Components
    Last Post: 07-30-2015, 09:17 AM
  4. Replies: 6
    Last Post: 10-05-2012, 11:12 AM
  5. DT 4.2 rim = which tubeless kit?
    By EBG 18T in forum Wheels and Tires
    Last Post: 02-12-2008, 05:28 PM
