comfortable 27.5 28 spoke rims- Mtbr.com
Results 1 to 10 of 10
    Reputation: jazzanova's Avatar
    I am looking for an advice. I would like to change my harsh enve Hv 70/30 rims for something more comfortable. I would like to stay around 28-32IW. Most likely will use my non boost King hubs.
    I am light at 140lbs.
    Mar 2017
    I had a set of I9 Hydra Trail S wheels and they rode considerably less harsh than my Roval carbon and Reynolds Carbon. I bought them in May had about 8-10 rides on them, just cut the hubs off and sent them to I9 to re-lace them to 29er rims, thats how much I liked how they rode.
    Make ya a smoking deal on a pair of 27.5 rims, lol. (28 hole- i27)
    Reputation: MSU Alum's Avatar
    Put 2.4+" tires on them and run lower pressures. Rims aren't going to make that much difference.
    Mar 2017
    I have to disagree, not to start a pissing match but I experienced the ride this past summer. My carbon rims one set i30 with 2.6 tires and one set i35 with 2.6 rode noticeably stiffer than the i27 aluminum rims with 2.3 tires. IDK...maybe I'm full of poo or I just wanted to believe as much but the proof was in the ride.
    West Chester, PA
    Just loosen up all your spokes a little
    Quote Originally Posted by gdb85 View Post
    No, you're not full of anything. I notice rim stiffness in steering, but with all of the absorption in tires (unless you're running 40 psi) I've never noticed it in ride comfort. +/- air pressure makes more of a difference, IME when it comes to harshness. Think about the impact deflection in a tire Vs. deflection in a rim - unless you're rim striking like crazy.
    Reputation: Lone Rager's Avatar
    Dec 2013
    No pissing. A typical mtb tire can easily compress 2" under and impact. How much does the rim compress under that same load? I'm gonna say less than a mm (2% of 2"), because if it was more, you'd always have your wheels going out of true and you'd be breaking spokes all the time.
    Do the math.
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Read Crank Brothers Synthesis reviews. Great compliant wheel set
    Quote Originally Posted by The Squeaky Wheel View Post
    These do look good. I live about 15min from Crank Brothers and know few guys riding these wheels. Not sure I want to invest in a whole wheel set, since my 27.5 bike is a non boost. I would rather just reuse my current Chris Kings which are both 28 spokes. That means running the same 28 wheel in the back as well...
    Quote Originally Posted by MSU Alum View Post
    2.35 schwalbe Magic Mary Addix which in reality is 2.5 and 2.5 Maxxis aggressor Exo 60 2c.
    16psi front, 18psi rear
  1. DT Swiss Rims - Is Beefy 28 Spoke Build Enough?
    By scuba6388 in forum Wheels and Tires
    Last Post: 11-09-2017, 01:48 AM
  2. How much weaker are 28 spoke rims vs 32 spoke likely to be?
    By trail-blazer in forum Wheels and Tires
    Last Post: 10-10-2017, 09:17 AM
  3. Replies: 16
    Last Post: 01-28-2014, 10:32 AM
  4. Rims, rims rims rims...
    By snaky69 in forum Urban/DJ/Park
    Last Post: 05-30-2006, 05:10 AM
  5. 28 spoke CX-Ray v. 32 spoke SuperComp
    By LowRent1 in forum Wheels and Tires
    Last Post: 03-18-2004, 09:52 AM
Members who have read this thread: 54
