Chris king 135mm to 142mm conversion- Mtbr.com
Results 1 to 9 of 9
    gio
    gio is offline
    Hi folks, I have done some internet searching for a while but still no luck finding the answer. I have just bought the Chris King 142mm axle that comes with a washer thingy. I just wonder where I should put that washer. Thanks
    It goes on the non drive side.
    High Ho Sultan, Lets GO
    Actual process for converting the King hubs?
    Is it really as simple as just buying a new axle, or is there more that is required? I had called Universal Cycles about this a while ago and I got the feeling that there was more to it than just the axle.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    It depends on the hub! If it post April 2007, then all you need is the axle. If it's pre April 2007 you will need the axle and the locking collar. The Stainless Steel end cap snaps on after the axle and locking collar are installed.
    Here are some links:
    http://chrisking.com/files/upload/hu...7_11_A_Web.pdf
    ISO Disc Hubs | Chris King Precision Components
    Hub Specs | Chris King Precision Components
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Quote Originally Posted by TurnerConvert View Post
    According to Chris King support, the proper p/n for the 142x12 Turner DW-link rear is PHB569, along with your existing adjusting clamp.
    Quote Originally Posted by mtnbiker4life View Post
    Perfect - thanks. I'm pretty sure these are pre-2007, so it is very helpful that you pointed this out. Much appreciated!
    gio
    gio is offline
    thanks for the reply guys, so much great info that is!!
    Plays with tools
    Reputation: customfab's Avatar
    Put it on the only side it will fit on, the non-drive side.
    gio
    gio is offline
    converted without any issues, took about 2 mins!!!
