Chinese DT hubs counterfeits- Mtbr.com
Results 1 to 36 of 36
    Reputation: Dominik.M's Avatar
    I've bought myself 2019 Anthem 2 29" and 2,2kg stock wheels are slowing this bike a lot, so I've decided to make a "cheap carbon bike wheels". This is the first part of this project: hubs
    After some research I've decided to remove bitex, novatec, formula from my interest list... On Aliexpress I've found the hub's that are looking almost exactly like DT350, so taking advantage of CHNY sales I've bought a pair of those:
    => vitoocycle Abgedichtete lager MTB
    vitoocycle 110x15, 148x12 (boost standard) CL disc hubs, It's a shame but there is there is no IS version. The star ratchet is 36T.
    After a month I've received a light package looking like a football ball
    On scale:
    Front hub:
    The adapters were hard to remove, they are a bit loose, the same is axle between the bearings inside the hub. The bearing's are no-name 6902RS.
    Rear hub:
    Chinese DT hubs counterfeits-vitoo_cycle_28h_cl_hubs_rear_star_ratchet_36t.jpg
    The adapters and free-hub body are easily removable by hand, all bearings and ratchet system are lightly greased. The ratchet system is 36T hollow version, the bearings inside the freehub body and hubs are no-name 6902RS.
    The look's nice. I can't compare them with original DT 350s hub's but judging by the look they are their exact copies.
    I'm still waiting for the rims, so after some time I will post the update.
    Jan 2017
    What rims have you purchased or are you still deciding?
    Giant Reign SX 29
    Ibis Ripley OG
    Santa Cruz Blur XCc
    Wow, I was expecting it to be koozer hub internals, but those really are straight up DT knockoffs!
    If you get the opportunity, it would be interesting to know if true DT stars fit in those hubs.
    The knockoff 54t ratchets have already been failures. The Chinese wheel/rim suppliers have already dropped them. Let us know about the 36t.
    West Chester, PA
    Wonder if the inside ratchet is threaded like a real one or bonded so that you'll never be able to change that bearing?
    Quote Originally Posted by 92gli View Post
    Good idea, I have the DT key and the original 18T ratchet, I'll cheek that later.
    Quote Originally Posted by meschenbruch View Post
    I'm betting on SpeedSafe 370g 29er 28X25 asymmetric rim's, they have a few positive reviews here.
    Hitching a ride
    Reputation: Schulze's Avatar
    Feb 2007
    It's not a counterfeit or knockoff. It's a copy. The patent has expired and it is no different than a Newmen, Syntace, Mavic 360, or koozer.
    Reputation: Millennial29erGuy's Avatar
    Feb 2017
    Quote Originally Posted by One Pivot View Post
    AKA “flower drum” on ali express
    My name is George. I’m unemployed and I live with my parents.
    2017 BMC Speedfox 25-622 ISO
    2017 Salsa Timberjack 40-584 ISO
    Feb 2019
    Interested on feedback.
    I like building J hook hubs. Here's a 350 hub from Bike 24.
    https://www.bike24.com/1.php?content...5D=1;orderby=3
    124 euros for a 148 Shimano rear.
    And a 15x110 front.
    https://www.bike24.com/1.php?content...ge=2;orderby=3
    54.61 euros. 1.15 dollars to a euro.
    I think the real thing is at a good price.
    Hello again,
    So the parts are fully interchangeable - and I was able fully disassemble the hub.
    DT Ratchet - as original as it can be .
    DT Rachet VS Vitoo ratchet
    Fitting inside the hub
    Vitoo hub close up
    Original DT Ratchet fitting
    Vitoo hub apart
    Enduro bearings ??
    Yes, it can be removed with the DT key.
    West Chester, PA
    Wow. Fully serviceable and the dt ratchets fit. I think these are going to be very popular
    Please post observations on how the centerlock rotor splines and lockring fit on these when you get a chance.
    Feb 2019
    Quote Originally Posted by Schulze View Post
    Do all of those have direct parts interchangeability with DT swiss? I find a lot with chinese copy products that if they can get the base body of the product correct that they may only drop the ball on parts that require correct metallurgy, in this case the ratchet parts, and those can be swapped for OEM parts and still save you a bundle of money.
    Not all, only this specific model.
    Feb 2019
    Ok, Schulze made it seem like all of them were the same.
    Hitching a ride
    Feb 2007
    Not really. It's not an exact copy but it's not a counterfeit either.
    Hitching a ride
    Feb 2007
    They wont be popular at that price. Maybe at half that price.
    I would argue with this, the price is almost the same as for the set of the light hubs from Bitex or Novatec - and at the same time, the DT overall construction is far more reliable. If they don't **** up something with the materials the price is reasonable.
    Novatec D711SB D712SB - around 120$
    Bitex MTF15 MTR12 - around 140$
    VitooCycles - around 150$
    Jan
    Jan is offline
    How are these holding up?
    Live Free & Ride
    Reputation: NH Mtbiker's Avatar
    It looks like this same hub can be bought in different sizes....like 135, 142 and 148mm rear & 100 or 110 front. Could be a good match to some DT rims I have waiting for a gravel wheel build. Notices that they also offer it with a 60T rachet upgrade! More feedback is needed before I can pull the trigger @ $180/set.
    17 Fuel EX 9.9 (in progress)
    19 FM 279 carbon gravel
    17 Stache 29+
    14 GT Zaskar 100 9r
    https://kettleheadbrewing.com/
    I don't have too much time to ride - but they work fine. Apparently better than a brand new original DT240S hub set bought from DT distributor in Poland - the bearings were so tightly pressed that the hubs were not rolling after the wheels were put together.
    Apr 2005
    How are these doing? still going? did you run them with the supplied ratchet or DT ones?
    All things considered, dt 350's aren't really much more expensive. Another 50 bucks if you catch sales.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by Dominik.M View Post
    If you were able to remove the threaded ring from an unlaced hub (not a built wheel) I would run, not walk, away from that hub. Regardless of price.
    I was under the impression that the ring would actually tighten under load/use and that was the reason why they are such a bitch to remove after 4-6 years of use? Is that an incorrect impression?
    I have 4 sets of wheels with DT ratchet hubs (3 240, 1 350) and haven't had to replace any bearings yet, but not looking forward to it. ;-)
    Aug 2003
    Quote Originally Posted by wfl3 View Post
    The threaded ring in a legit DT hub is not able to be removed -- even when new, unridden -- from an unlaced hub. And yes, over time, it still tightens in there.
    If the threaded ring is installed so loosely in these knockoffs, it has the potential to thread so far/so fast into the hub that it'll split the hubshell on your first few pedal strokes. I've seen it happen with other (cheap) hubs.
    At that point, how far ahead are you when you have to unlace the wheel and relace (at minimum) a new hub shell in there?
    Thanks for the information/explanation Mike.
    Nov 2018
    On scale:
    Front hub:
    Rear hub:
    Can you give an update on how these are holding up?
    Aug 2020
    It looks to me like the ratchet ring was removable because it hadn't been used yet. Not defending the hubs but if that's the case it's not a mark against them. Now, the legitimate DT hubs new EXP design- ha, now that's a torqued thread I would walk away from.
    Aug 2020
    Only the new EXP design is threaded and it looks like a terrible idea. This is a copy of the older, better design.
    Jul 2019
    those clones will holdup fine, and you should be able to remove the threaded ring. I had a set of powerways, put a 1000 miles on them, and just switched out for a pair of dt350's, and the bearings on the powerways were still just as smooth as the new dtswiss bearings.
    will run a 60t clone ratchet myself
    I have smooshed those blue enduros in tens of miles. My <150lb wife has too.
    Which is fine. Bearings go out, whatever. But add on $90 to the cost of the hubs to replace the bearings, maybe pretty early on in ownership, and the attractive original price gets kind of unattractive.
    And that assumes you do your own labor. If not, forget it, you're so far behind at that point it makes no sense.
    I like finding cheap bargain parts that are awesome, but its increasingly less common hubs. Cheap hubs end up sort of expensive sometimes.
    Theres always shimano hubs sitting right there too, for dirt cheap with huge monster bearings that run smooth forever.
    Quote Originally Posted by shoots View Post
    Hello, almost after a year they work fine, I cannot complain about anything
  1. Hubs hubs hubs
    By reamer41 in forum Wheels and Tires
    Last Post: 01-09-2018, 02:31 AM
  2. Replies: 0
    Last Post: 02-06-2015, 04:58 PM
  3. hubs hubs hubs
    By rho in forum Singlespeed
    Last Post: 05-31-2013, 07:34 AM
  4. Replies: 11
    Last Post: 01-31-2013, 05:17 PM
  5. not just a chinese carbon frame, but 90% chinese!
    By menusk in forum Bike and Frame discussion
    Last Post: 06-22-2011, 01:53 PM
Members who have read this thread: 178
