Can you run a fork boot and still run tubeless- Mtbr.com
Results 1 to 2 of 2
    I did a search and no luck.
    I have a maxxis Ikon that i have ridden less than 10 times and i tore the sidewall on a ride last night
    I am tempted to put a park tire boot over the rip and try and go tubeless again. Tires are ridiculously expensive and I am unemployed so i really want to try it but I am guessing once i hit the tire with the air compressor up to 60-70 psi that the sidewall will herniate and I am back to square one.
    Any experience or input?
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    1) don't go anywhere near 60-70 psi.
    2) i've done it without issue, though your success is going to depend on the tear and how well you make the repair
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
