Can pull off cassette with freehub inside by hand- Mtbr.com
Results 1 to 9 of 9
    Apr 2016
    Hi
    I upgraded my wheels and want to build from the old ones a XC spare set.
    I put on the XD hub my Sram cassette an used a torque wrench to tighten up the cassette. At the end I pulled from behind, just to check if it sits correctly, and suddenly I had the whole cassette with the hub in my hands. It looks like the hub sits inside the cassette.
    I have no idea why this happened. Shouldn’t the cassette be firmly connected? I can put on the cassette and it looks fine and the hub runs smoothly.
    Reputation: WHALENARD's Avatar
    Feb 2010
    What kind of hub?
    Yeah that's normal with most any modern hub. I'd clean it up and add a little bit of freehub oil.
    Sent from my moto g(6) forge using Tapatalk
    It is no measure of health to be well adjusted to a profoundly sick society.
    Apr 2016
    Thanks for the quick response! It is a DT Swiss hub from 2016. Didn't know you can just pull it off. Thought there must be something wrong.
    Feb 2010
    Yep, that's in the design. I'd go ahead and get some hub oil (do NOT use grease), clean everything up and oil it.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Actually, you should use the DT-specific ratchet grease. Not oil.
    Death from Below.
    Jan 2009
    if the cassette came off, that is a problem!
    if the freehub came off with the cassette attached, that makes sense.
    everything should stay in place when you mount the wheel on the bike. if the freehub or cassette move around with the wheel mounted on the bike, that's a big problem too.
    Feb 2010
    ^Good call LeDuke.
    I've used dumonde tech on my road set for ages though. So far, so good.
    Reputation: MSU Alum's Avatar
    Grease for DT, oil for Torch, so it will vary by manufacturer and hub.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    OP, yanking the freehub body off with cassette is exactly how you would service DT hubs on the trail if ever needed. (to replace broken star ratchet).
    Check out their website, they actually have a video of this trailside repair.
  1. Can Freehub teeth inside the wheel be replaced?
    By ET_SoCal in forum Wheels and Tires
    Last Post: 03-27-2020, 08:57 AM
  2. Can Someone Tell Me If This Pictured Derailleur Is Dual Pull Or Only Top Pull?
    By michael1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-08-2014, 01:47 AM
  3. FD - how can I know if it is dual pull or top pull?
    By xenon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2012, 12:49 AM
  4. Front Der Question - bottom pull, top pull?
    By ProjectDan35 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-31-2011, 05:31 PM
  5. conversion for top pull cable to bottom pull deraillier
    By jbchybridrider in forum 29er Bikes
    Last Post: 03-14-2011, 08:51 AM
Members who have read this thread: 45
