Can I replace a 2.0 width spoke with a 1.8?- Mtbr.com
Results 1 to 6 of 6
    May 2014
    The spokes I received claimed to be 2.0 width but when I measured them they came out to 1.8.
    Is there any issue with using a slightly smaller width spoke? I am mostly concerned that the treads with strip with the older nipple. This is for mountain biking.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Don't use 2mm nipples in 1.8 spokes, you will certainly end striping the treads for one or another reason.
    Didn't the spokes had nipples included?
    May 2014
    Quote Originally Posted by Aglo View Post
    They didn't come with nipples. I only ordered a pack to fix a broken spoke.
    turtles make me hot
    Reputation: NYrr496's Avatar
    You can use either 1.8 or 2.0mm spokes in a wheel but you have to use all the same and the correct corresponding nipples.
    Don't replace one 2mm spoke with one 1.8 when the rest of the wheel has 2mm.
    I like turtles
    Braaap
    Reputation: DirtMerchantBicycles's Avatar
    May 2014
    Check to see if they are butted...1.8 in the middle and 2.0 on the end.
    Dirt Merchant Bicycles
    Providing unrivaled support and unbeatable pricing on all cycling goods to riders near and far.
    Most hubs are drilled with a hole for a 2.0mm spoke.
    You'll be more likely to get spoke movement using the 1.8s.
    Get the correct size spokes.
  1. new wheel build (LB 29er 30mm inner width) spoke suggestions
    By cunningstunts in forum Wheels and Tires
    Last Post: 07-05-2015, 06:33 PM
  2. Replies: 3
    Last Post: 04-22-2014, 11:28 PM
  3. Replies: 16
    Last Post: 01-28-2014, 10:32 AM
  4. Replace spoke or full rebuild?
    By R+P+K in forum Wheels and Tires
    Last Post: 02-05-2012, 06:35 PM
  5. Replace Single Spoke?
    By BQuicksilver in forum Wheels and Tires
    Last Post: 05-10-2011, 01:29 PM
