Can anyone recommend a presta adapter for an air compressor?- Mtbr.com
Results 1 to 12 of 12
    For sealing up tubeless I've been using an presta adapter (https://www.amazon.com/Slime-23042-A...g-goods&sr=1-9) but it's a pain to use - have to turn the presta valve just right or it doesn't work and the schrader adapter leaks if not held perfectly straight
    The only thing I can find is Prestaflator but I don't really want a gauge
    Aug 2016
    I use my small compressor with a piece of flexible plastic tubing attached to the blowing/dusting nozzle. Remove the valve stem, seat tire with air, put the valve back in, re-inflate and test for seal before adding tubeless brew of your choice.
    Bicycles don't have motors.
    Oct 2019
    I have had this one for a few years now and have never had any problems with it.
    Prestaflator Mini - Bicycle Tire Inflator - Presta Air Compressor Tool https://smile.amazon.com/dp/B014PXMF..._NXATDbRRNR3NQ
    Sent from my SM-G960U using ****************android_app_mtbr
    Reputation: Lone Rager's Avatar
    Dec 2013
    I like the Topeak Twin Head.
    https://www.amazon.com/s?k=topeak+twinhead
    Do the math.
    ok seeing some more options now. looks like this
    https://www.amazon.com/Prestacycle-R...17577732&psc=1
    will work with my existing schrader adapter for the air compressor
    https://www.amazon.com/EPAuto-Heavy-...188864&sr=1-21
    Reputation: In2falling's Avatar
    Jan 2005
    Quote Originally Posted by turquoise View Post
    Really don't need to use any type of adapter. Just remove the presta core all together when seating/sealing your tires(beads).
    With the presta core removed you just have to tilt the compressor nozzle as you are pushing it on to the stem. You get much more air flow this way with the core removed. Once tire beads are seated reinstall cores and use a floor pump from there.
    Dec 2013
    We call that a crack pipe and use it for inflating aero disc wheels which don't have clearance for anything else. It'll work, but it wouldn't be my first choice.
    Any decent air chuck off a floor pump (or replacement for one) can work well. You just have to adapt its hose to connect to your compressor.
    Do the math.
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Quote Originally Posted by In2falling View Post
    +1
    This is, by far, the best method for rapid inflation and sealing of tires
    Reputation: Rngspnr's Avatar
    Feb 2016
    This
    2016 Evil Following V1
    2016 Dartmoor Primal+
    Reputation: sturge's Avatar
    Quote Originally Posted by Rngspnr View Post
    This
    I only use compressor when seating beads of new tires and these have always worked fine for me. I remove valve cores to get highest air flow to seat beads.
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...:thumbsup:
    You all are geniuses. Removed the core and super easy to setup tires. My only complaint now is sometimes the valve cores are hard to remove and hurt my delicate fingers. Anyone know of a tool that would slip over and make it easy to remove?
    Jun 2016
    Several options. My tubeless repair kit comes with a tool on the bottom. However I usually use a regular spoke tool like this:
    Can anyone recommend a presta adapter for an air compressor?-cle_a_rayon_multi-taille_velo_moto_multi_spoke_wrench_bike_motorcycle_xxe.jpg
  1. Air compressor presta adapter
    By johnb in forum General Discussion
    Last Post: 01-29-2017, 12:56 PM
  2. Presta Valve inflation with an Air Compressor
    By campybike in forum Tooltime
    Last Post: 07-08-2014, 03:03 PM
  3. Replies: 21
    Last Post: 02-19-2013, 12:57 PM
  4. Air compressor with Presta / Schrader converter
    By dirtbyte in forum Wheels and Tires
    Last Post: 09-30-2012, 01:37 PM
  5. is there a way to inflate presta valves with an air compressor?
    By ussprinceton2004 in forum Wheels and Tires
    Last Post: 09-18-2011, 11:43 AM
Members who have read this thread: 70
