Results 1 to 13 of 13
    Boost adapters or new wheel?
    Got a new bike and the wheels weight quite a bit more than what I wanted.
    Have a set of carbon wheels that are light.
    So is adding boost adapters a good option or just buy new wheels?
    Do I just add the adapters and ready to go , or more work is needed?
    Adapters $44
    New wheels at least $1,000
    Always in the wrong gear
    Reputation: Impetus's Avatar
    Aug 2014
    Need more info. What hubs?
    A WolfTooth boostinator kit with spacers that stay with the wheel are not bad. Hope and DT are the 2 that come to mind.
    I have a front wheel (Hadley hub) that is boost converted using 2 5mm axle spacers and a 5mm disc shim. Itís a huge headache. Every time I pull the front wheel one or both of the axle shims rolls away. Iím terrified Iíll get a flat on a night ride and lose one on the trail.
    Donít modify the trail to match your skills, modify your skills to match the trails.
    If you can build your own wheels, I would swap hubs to boost hubs. I just bought a boost bike, and that's what I ended up doing. I paid for boost, I want boost!
    Ill be the first to admit its a marginal gain that you probably cant feel or notice the majority of the time. If you're paying for the swap, its a bit silly to consider. The boost adapters work just fine.
    I cannot build my wheels, that would have been the best solution.
    Boost adapters then?
    They are cheap enough to try :https://www.amazon.com/VeloFuze-Boos.../dp/B01N0GXOGS
    I run the VeloFuze adapter on my fork w/o any issues.
    fat & decripit old guy
    Mar 2011
    I use a boost adapter kit and have no issues.
    Same as you where I built an expensive carbon wheel set and then one year later purchased a new bike with boost spacing, still wanted to use the wheel set.
    Ali express $15
    Jan 2017
    I have a Novtec front hub and was looking at a generic kit as you described with 2 spacers and a disc shim. Aside from the problem of loosing the axel shims when you take the wheel off, does it work fine when in place? I would probably just buy some extra axel shims and put them in my kit.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by jayhenryrules View Post
    Works perfectly. Have run it all last season on multiple bikes. Much ado about nothing.
    Check out the MRP boost kit. It replaces both end caps and provides a disc brake spacer. No redish required.
    I do build my own wheels and have setup several boostinator kits for buddies. Those wheels are all holding up great and I wouldnít have issue using them if needed.
    https://mrpbike.com/products/better-...onversion-kits
    Jan 2019
    Quote Originally Posted by motoadve View Post
    Adapters $44
    You need to shop around more. I picked up a set of Mulefut 50 boost wheels on Amazon for $3xx a few months ago, that's 60% less than MAP.
    There are deals out there on boost wheels if you look.
    Lots of demo wheels that have never been ridden, many never even had a tire mounted.
    Reputation: the_joe's Avatar
    Feb 2017
    +1 for boost adapters. Get them and ride it out until boost goes away and the next axle standard becomes fashionable
    2008 BMC Fourstroke 19-559 ISO (RIP in peace)
    2017 BMC Speedfox 25-622 ISO
    2017 Salsa Timberjack 40-584 ISO
    Can someone please link me to the correct Boost spacers I need. my wheels came off a 2018 camber. They are Roval Traverse 29mm inner diameter with specialized hubs. Some kits I see are hub specific. I want to make sure I'm buying the right one.
    Mar 2011
    Quote Originally Posted by ecooke21 View Post
    Just go to AliExpress and order the generic ones. This will be your best bet
  1. Replies: 9
    Last Post: 04-25-2018, 01:56 PM
  2. Boost wheel adapters on a Stans Arch rear wheel
    By eastsiderider in forum Wheels and Tires
    Last Post: 11-21-2017, 05:45 PM
  3. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  4. Wheel companies with Boost adapters?
    By aliikane in forum Wheels and Tires
    Last Post: 08-08-2017, 11:22 AM
  5. Replies: 2
    Last Post: 05-06-2017, 05:00 AM
Members who have read this thread: 100
