Results 1 to 3 of 3
    Dec 2018
    New question here. Azonic Outlaw 29s on Honzo ST
    Hello this will be my first post on MTBR.com forums so thank you in advance for all the help my question is I just purchased a set of a azonic outlaw 29 er wheels and Iím wondering if this is going to work on a 2015 Kona Honzo ST with sliding rear drop outs the dropouts currently have a 12 x 142 spacing and axle size and I will be purchasing the conversion kit for the rear hub to convert to a 12 x 142 axle the only issue that I see right now is that the rear hub needs to use a thru axle and I have a quick release that threads into one side of the dropouts is this something that can Be converted to be used with a 12 mm quick release axle or am I stuck with a through axle and do I need to machine out the drop out to except a through axle so I can nut both sides ? I will also be converting this wheel set to a single speed set up using an origin 8 rear hub conversion system is this going to cause any issues with the thru axle or quick release it looks to be a pretty simple straightforward swap however Iím not finding a ton of information online about using the Xanax as a single speed wheel with the Kona hands out if anyone has any information or has any experience with this can you please chime in thank you very much pictures would be great if anyone has any .
    Reputation: ChvleSS956c's Avatar
    You can use your thru axle as is, no need to. Odiferous anything once you convert the hubs
    Sent from my iPad using Tapatalk Pro
    Dec 2018
    Ok thanks bud !
  1. Honzo v. Big Honzo sizing. Who's been on both?
    By goalieman24 in forum Kona
    Last Post: 11-07-2017, 08:20 PM
  2. when is pricepoint gonna drop price on azonic outlaw
    By hahdtail in forum Where are the Best Deals?
    Last Post: 05-20-2011, 10:25 AM
  3. Azonic Outlaw 29er
    By jdefran in forum 29er Bikes
    Last Post: 03-09-2011, 09:10 AM
  4. Azonic Outlaw wheels tubeless?
    By hoolie in forum Wheels and Tires
    Last Post: 03-06-2011, 12:24 AM
  5. Azonic Outlaw 135mm and 150mm?
    By Blksocks in forum Wheels and Tires
    Last Post: 02-16-2011, 10:26 AM
Members who have read this thread: 16
