Any body know if Hope pro hubs (pre pro 2) are convertible to 15mm- Mtbr.com
Results 1 to 3 of 3
    Reputation: string's Avatar
    Does any body know if the Hope pro 2 front hub 15 mm conversion will fit the older Pro Hubs (circa 2005 convertable from qr to 20mm)?
    Ordering a new 15mm fork & hoping I can convert an existing hub.
    Contact Hope directly - their CS is pretty good usually and I'm sure they can point you in the right direction. Worst case you could probably convert them to 20mm and then get some sort of adapter that lets you run 20mm hubs on a 15mm QR skewer.
    Fred
    I did end up calling Hope. The hubs were not.
    Will just keep them as a back up for another bike and ordered a 15mm wheel set.
