Results 1 to 3 of 3
    Oct 2018
    ANNOYING SQUEAL coming from Dt Swiss m1900 spline. Fix?
    Front wheel making constant high pitched squeal,( not an issue with the rotor rubbing) Iím using a greased carbon-ti rs thru axle? Any ideas of how to fix this problem?
    Bad bearing? Iíve had front bearings start to go and sound like a squeaking mouse was following me. I mean, youíre axle has a light layer of grease, the brake isnít rubbing, so Iíd pull the wheel and spin it in my hand. Bearings.
    Try greasing the front bearings with trans fluid. It'll clean out stuff like possible rust and extend the life. After you get it rolling without noise it would be usefull to work bearing grease in if possible. If a seal can be popped off it'll be easier to press grease in.
  1. Mavic Crossride or DT Swiss M1900 Spline for 27.5
    By Akio in forum Wheels and Tires
    Last Post: 03-19-2015, 11:57 PM
  2. Replies: 8
    Last Post: 03-17-2015, 08:48 AM
  3. Dt Swiss m1900 hubs help
    By yeti575inCA in forum Wheels and Tires
    Last Post: 04-23-2013, 10:16 PM
  4. Replies: 5
    Last Post: 09-11-2011, 04:40 PM
  5. Replies: 2
    Last Post: 09-10-2011, 08:47 PM
Members who have read this thread: 22
