acceptable rim defects?? (new alex blizzerk - are these likely 2nds?)- Mtbr.com
Results 1 to 8 of 8
    Jul 2017
    The issues with these (new) rims below seem serious to me. What are your thoughts?
    I bought two pair of alex blizzerks (same seller). They arrived with no immediately noticeable shipping damage. HOWEVER I was _really_ surprised at some glaring quality issues, at least as compared to the > 10 other rims/wheelsets I've had on my & families other bikes (and set up tubeless... so you know, paying attention.)
    Alex blizzerk 90 (not SL, ~hybrid single/double wall). Pinned joint. All look perfectly round to the naked eye, haven't got around to measuring ERD to order spokes yet.
    problems:
    • visible "air gap" in one of the rims. Easily slide 2 layers of paper in the gap
    • slightly diagonal joint/seam on two of the rims. Off enough to be obviously visible.
    • ~1mm jump at the joint in the center of the rim (single layer Aluminum at that point).
    Pictures, in order, below
    Jul 2017
    it was really easy to slide this folded paper in. Could probably fit more. round up to 1mm?
    acceptable rim defects?? (new alex blizzerk - are these likely 2nds?)-air-gap-rim.jpg
    Jul 2017
    I wasn't looking for issues like this, the joint is diagonal enough to be immediately visible
    acceptable rim defects?? (new alex blizzerk - are these likely 2nds?)-diagonal-seam.jpg
    Jul 2017
    3 of the 4 rims have really bad joint matching. The bead seats are ~pretty close, but the center is way off. Obviously not going to be perfect all the time for a non-welded (and ground) rim, but this seems really high?
    acceptable rim defects?? (new alex blizzerk - are these likely 2nds?)-rim-discontinuity.jpg
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    normal for a mid-lo range fatbike rim
    (alexrims are general purpose rims, not high end, imho and experience)
    my mulefut80 have a gap at the weld that is similar... it's straight but can fit paper in.
    alexrims in my experience are plenty stronk....
    just run it, dawg.
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    The gap and the uneven vertical alignment would not make me bat an eye, but the slanted joint would make me return the rim. But that's me.
    Alex rims are kind of janky.
    Jul 2017
    ok, thanks for the replies. I don't care about the aesthetics, bikes are dirty ...
    if no one has any concerns about durability (or, especially whether I was sold 2nd's without being told), then I'm fine with it. Will just have to seal that crazy gap for the toobless...
  1. Tell me about Alex Blizzerk tubeless rims/wheels
    By CycleKrieg in forum Fat bikes
    Last Post: 02-04-2019, 10:37 AM
  2. Alex Blizzerk SL90 rims
    By Willum in forum Fat bikes
    Last Post: 03-27-2018, 02:11 AM
  3. Blizzerk 80 by Alexrims
    By slower_than_u in forum Fat bikes
    Last Post: 09-17-2014, 06:47 AM
  4. ALEX CR18 vs. ALEX HRD 32 hole ?
    By MTBCanuck in forum Wheels and Tires
    Last Post: 12-28-2011, 09:55 PM
  5. Alex DM-24 versus Alex MX-22?
    By londonlad in forum Wheels and Tires
    Last Post: 10-19-2004, 09:21 AM
Members who have read this thread: 52
