Results 1 to 9 of 9
    Dec 2008
    30 or 35 mm IW for 2.35-2.6" tires?
    Hi all,
    Looking into potentially getting the Enve M630 or M635 rims, alternatively the Ibis 935 (29 mm iw) or 942 (35 mm iw). My plan is to run Schwalbe 2.35 Magic Mary front and maybe a Hans Dampf or Nobby Nic 2.35 rear. Schwalbes do run pretty large, in my experience comparable to Maxxis 2.5 WTs. Down the road I might try some 2.6 tires, but the idea is to have the 2.35 as the go-to setup.
    Given this, would you opt for a 29-30 mm internal width, or 35mm?
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    29mm
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    Quote Originally Posted by Schulze View Post
    29mm
    I'm on 29mm. ibis 935 carbon. Had the 942 35mm and like the 29mm better.
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    Nov 2017
    We have i36mm and i35mm rims. 2.5/2.6in is the smallest would go. We normally run 2.6 to 3.0. we knew that we would not run anything smaller than 2.6. Remember, tires normally measure smaller than the actual size. Depending on the tire, 2.5in already starts to get squared off.
    I ran 2.5wt Maxxis on my old bike with i29mm-ish Stan's rims. They fit great and performed well. The tire may have been slightly rounded, but I did notice. Iran the same tire on my wider rims and I absolutely hated it. I think the bike originally came with 2.2 or 2.3in tires.
    My two cents is stay around i30mm.
    Sent from my SM-G930U using Tapatalk
    Out spokin'
    Dec 1999
    I’m running i30.5mm rims with 2.6” tires, they’re great. I also wouldn’t hesitate to run i35mm rims with this size tire.
    If I were running tires narrower than 2.5”, personally I’d certainly stick with rims in the i30mm range.
    =sParty
    disciplesofdirt.org
    100% PRIME ALBERTA BEEF
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    2.3 Minions on id 27mm WAO Insider rims. Good profile, no complaints (except my MaxTerra DHR2 is a little draggy, but that's the tire, not the rim).
    I had a set of 2.3 E*13s on E*13 id 31mm carbon rims. In my view, a little flat. A little low profile. And a little square. In my view, the E*13s may have worked better on the id 27mm rims.
    I'm going with a 2.5 Maxterra DHR2/2.5 DC Aggressor combo on id 30mm WAO Agent rims for a new build. The profile looks bang on, although I am still waiting for the temps to rise above minus 25 C before I give them a shot...
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Quote Originally Posted by mtnbkrmike View Post
    Stop shouting.
    Nov 2017
    Calmly cracked the code
    2.3 27mm Good
    2.3 31mm Square
    2.5 30mm Profile looks bang on
    Mar 2015
    Quote Originally Posted by Miker J View Post
    Stop shouting.
    Damn. Sorry about that. It was done with nothing but the best intentions. I thought it provided an easier summary at a glance.
    Apologies again.
  1. Replies: 4
    Last Post: 03-28-2018, 10:51 AM
  2. "pow" "krunch" "plop"
    By DIRTJUNKIE in forum Off Camber (off topic)
    Last Post: 01-20-2013, 12:15 PM
  3. Replies: 12
    Last Post: 05-31-2012, 05:19 AM
  4. Replies: 2
    Last Post: 03-31-2012, 07:30 PM
  5. "Kliane" "Klein" "Quasi Moto" "Paul"
    By stan4bikes in forum Vintage, Retro, Classic
    Last Post: 08-20-2007, 03:36 AM
Members who have read this thread: 97
