29er Tires for commuting to work and some mtn biking.- Mtbr.com
Results 1 to 10 of 10
    Is there a tire that I can use on my Air9 to commute to work and ride up some trails after work without tearing up the threads to badly? I don't want a Street tire but something in between. Low resistance yet good on both terrains.
    Thanks in advance
    Nov 2012
    I've been using Spec Ground Controls that came on my bike just for this purpose. They are proving to be very durable and working well as an all-around tire. Definitely not the best on rolling resistance, but cant complain for an off-road tire being used on pavement.
    In doing some research, the Kenda Small Block has been highly recommended. May want to take a look into those.
    Reputation: Bruski's Avatar
    +1 for the Small Block Eights. I commute an trail ride with little issue. I'm building a second front to mount a Ralph on when the trails are too soft. Otherwise, SB8s are a good fast rolling tire. Just stay out of the mud.
    Sent from a cliche device from a cliche location...
    no trees are safe
    Reputation: Millfox's Avatar
    Jun 2012
    Schwalbe Smart Sam, Maxxis Crossmark, Continental X-King, Michelin xc Dry 2, Kenda Karma...
    Thanks all. I'm really leaning towards the Small block 8 but noticed they don't make a Tubeless / UST version of it in 29". Any recommendations on a tubeless ready 29er for the same purpose?
    I'm running them tubeless on my Niner. Stans Arch EX.
    May 2013
    +1 for the Kenda Small Block Eights. Not the best off road tires but they have low rolling resistance for pavements, they are fairly firm rubber so they won't wear down as fast as some other tires and fast on smooth single track and gravel. Absolute crap on wet/mud and on roots and rocks.
    May 2013
    Quote Originally Posted by TACORICAN View Post
    Another option would be the Maxxis Ikon exo. That work well on Stans. The Small Black 8's are next to impossible to setup tubeless with any reliability.
    Reputation: GTscoob's Avatar
    Quote Originally Posted by Lemonaid View Post
    I love the Ikons but they dont hold up well to pavement riding.
    Kenda DTC Small Block 8s would be a good recommendation but you'll still burn through a set or two a year. Have always figured that a Slant Six up front and SB8 out back would be a killer compromise setup for riding road and minimizing drag.
    Nov 2012
    There is a tubeless version. Kenda calls it SCT..
    Here is a link to a tubeless version
    Kenda Small Block 8 29" DTC SCT Tire > Components > Tires and Tubes > Tires | Jenson USA Online Bike Shop
  1. 29er snow tires--first year biking in the winter
    By mountaindavis in forum Colorado - Front Range
    Last Post: 10-05-2012, 10:35 AM
  2. Newbie needs help What 29er tires for road work/ exercise?
    By excaliber in forum Beginner's Corner
    Last Post: 05-15-2012, 06:37 AM
  3. Replies: 38
    Last Post: 10-09-2011, 06:29 PM
  4. commuting tires and fenders for 29er
    By youthfull in forum Wheels and Tires
    Last Post: 10-02-2011, 10:14 AM
  5. Replies: 4
    Last Post: 03-11-2011, 12:53 PM
