Results 1 to 7 of 7
    Reputation: darth biker's Avatar
    2.7 tire in 27mm rim
    Hello
    Was wondering if I could set this up tubeless ? Thoughts?
    Luke, this is your father's lightsaber. I cut him in 1/2 to get it.
    Oct 2018
    Tubless setup requires 2 things -a rim that can be sealed with tape.
    A tire that is rated as tubless ready. You CAN use a non tubeless ready tire but it will seep more quickly.
    It seems though like in general, the rim is too narrow, or the tire is too wide to be a good match.
    Others know more than I do and the only experiences is the stock 31mm Specialized Roval with the stock 2.35 tires.
    Dec 2016
    The consensus is that a min of 30mm inner rim width is required to run tires larger than 2.4." Larger tires would work but you need to inflate them higher to get a stronger sidewall and without having them rolling off the rims. Of course, that would defeat the purpose of having a larger tire with lower air pressure.
    Ahhh the pain....
    Reputation: Raybum's Avatar
    I ran a 29x3 Chupacabra on a Stans Crest rim (21mm inner) for a few thousand miles of singletrack without issue. Inflated it to 13 psi. (I'm 160lbs). Worked fine till I built up a proper wheel.
    Oct 2018
    Quote Originally Posted by SingleSpeed73 View Post
    The consensus is that a min of 30mm inner rim dia is required to run tires larger than 2.4." Larger tires would work but you need to inflate them higher to get a stronger sidewall and without having them rolling off the rims. Of course, that would defeat the purpose of having a larger tire with lower air pressure.
    30mm width, not diameter.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Quote Originally Posted by darth biker View Post
    Hello
    Hey, could you slow down with the details? I can't process all this info at once.
    Ty for the responses. I had a 2.3 lying around and went with that instead.
  1. 25-27mm carbon rim? Any favorites?
    By One Pivot in forum Wheels and Tires
    Last Post: 11-22-2018, 05:37 AM
  2. Light-Cycle 27mm wide, 29er carbon hookless rim
    By Johnny Chicken Bones in forum Wheels and Tires
    Last Post: 08-26-2016, 06:08 AM
  3. Dirt Wizard on 27mm rim?
    By hiphopopotamus in forum Wheels and Tires
    Last Post: 03-27-2016, 11:39 PM
  4. Will spokes from a 27mm wide rim work on a 29mm wide rim?
    By daemoncycler in forum All Mountain
    Last Post: 02-25-2015, 02:41 PM
  5. Rim Size: 33mm vs 27mm?
    By kenpress in forum 27.5
    Last Post: 02-15-2015, 07:12 PM
Members who have read this thread: 48
