Results 1 to 42 of 42
    Reputation: ridetheridge's Avatar
    2.5 DHF / 2.3 Agressor alternatives
    Looking for a bit lighter and faster rolling combo for my long travel 29er.
    So far, I'm leaning toward 2.6 Rekon on front but not sure about the rear. Rekon 2.4, Forekaster 2.35 or Ardent 2.4 ? Anyone know the rolling resistance between those three ?
    Not necessarily tied to Maxxis. Open to suggestions.
    I'm also assuming the Rekon 2.6 will roll faster than the 2.5 DHF, i know it's quite a bit lighter.
    My conditions are front range , CO dry and rocky.
    The Mtn Bike App --> http://mtbphotoz.com
    Reputation: sethd513's Avatar
    Jun 2016
    I was about to try that combo then bontrager came out with the 2.6 se5. Iím running 2.6 se5 front and 2.4 se4 rear. Yes the 2.6 is about 1/8 inch taller off the rim but I have more controls and much faster then front and rear se5 2.3. Nice soft tires tons of grip
    Dec 2013
    I have been on a front DHF 29 x 2.5 3c & a Maxxis Aggressor 2.5 Dual for several sets. I had tried so many others and did appreciate some better rolling resistance of other tires but always missed the absolute traction.
    Lately (it's been flippin hot and humid here!) I have been very aware of the RR but also came to recognize that the rear Aggressor 2.5 almost had too much traction. Never letting go even when the front was gone.
    Carefully reading reviews, trying to decipher the infinite BS and differing opinions I settled on 2 replacements: the Specialized Butcher 2.6 (which I was glad only measures about 2.4 cause I don't think much of plus tires) & the new Hans Dampf soft snakeskin with a Pepi tire noodle installed (i'm a total WW but can roll a snakeskin right off a rim under hard cornering).
    I can't say which end offered how much improvement but it's my opinion both offered RR improvements. Essentially the front Butcher is like 5% less traction than the DHF. Noticeable but minor. It seems like it might want a bit less air pressure which I will experiment with too skate less.
    The rear HD probablly has like 15% less traction than the Aggressor but I really didn't need all that traction the Aggressor offered. So I really gave up little to nothing as far as traction goes. The rear HD feels a ton like the old WTB Breakout, with better wear hopefully.
    These tires are more narrow which I appreciate. The bike turned much quicker. I'm over plus tires!
    As far as RR, BIG improvement. Very happy, and bike is so much more sprightly. After one good ride on these things, I have a new favorite set up for sure. To try and quantitate the improvement, if a set of no traction super fast XC tires would be a 100% improvement in RR (not really attainable with proper tires) I'd say these tires gave me a solid 25% improvement in RR, which is huge!
    Some of those XC tires listed above aren't even in the same category so not sure why those are listed as possibly replacements for DHF/ Aggressor. They are for a different kind of riding/ bike.
    Take care
    Sent from my SM-G892A using Tapatalk
    Nov 2017
    How about xr4/se4 front and McFly rear?
    I'm running a 29x3 XR2 front with a 29x2.8 McFly rear and its great. Way more xc than the dhf, but that's what I was looking for.
    The xr4/se4 is a great all around tire.
    Sent from my SM-G930U using Tapatalk
    Nov 2017
    I have been running a 2.6 Rekon up front with a 2.4 Ardent rear on my 27.5 bike for over a year and a half. It has been a great combo. I have never lacked for traction except in wet conditions which I really try and avoid. I had a 2.4 Ardent up front for awhile and the Rekon 2.6 is a noticeable improvement. But out back the Ardent rolls surprisingly well and has given me the traction that I need. My Ardent is about done so I am considering a replacement just to try something different. I also am thinking about either a 2.6 Rekon or 2.4 Rekon. Hard to find any reviews on the 2.4 version. I have tried heavier tires like the DHF and they do have more traction but for me I can ride longer with less energy on tires like the Rekon and Forekaster without traction issues. Suns_PSD post in the first paragraph summed it up best. There are other tires with better rolling resistance but he always missed out on the absolute traction of a DHF kind of tire. That is a completely accurate point of view. The DHF has awesome traction. But for me less rolling resistance was more important than absolute traction. I think with tires sometimes you just have to spend the $ and give them a shot and see what is best for you. I will say my wife has the 2.4 Bontrager XR4s and she loves them. Noticeably better traction than the Ardent up front but still rolls pretty well. And I believe you can try out Bontrager tires for 30 days and return them if you don't like them. I may try a 2.6 XR4/ 2.4 XR4 combo at some point myself. There really are some pretty good options out there.
    Reputation: johnD's Avatar
    Quote Originally Posted by Spur11 View Post
    I have XR 4 team issues on my bike , I don't think they roll that well. The rear is wearing out faster than any other tire I've ever had.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    You ride on rocks johnD? I love the grip and feel of Bontrager tires but they do wear fast in certain terrain. The vittoria Goma is similar to the XR4 and has excellent durability....but is 300g heavier.
    Quote Originally Posted by Schulze View Post
    limestone rocks with loose over hard dirt in between also hardpack. do you think a goma or martello would work well for that type of terrain ?
    Barely in control
    Feb 2007
    Yes, the Goma 2.4 is awesome for this terrain. The Martello I was less impressed loose over hard because the lugs are too close together and it skates over pebbles. But Goma will be heavier, and you need clearance for 2.6".
    Rocks belong
    Only caveat on the Goma - I find they stink on off camber grip.
    I like 'em long, low, slack and playful
    I've got plenty of clearance. Thanks brother.
    36 styles of danger
    Reputation: silentG's Avatar
    You didn't mentioned tubeless ready or not but I'm going to assume tubeless.
    Conti Trail King 2.4 or 2.2 Black Chili front/rear?
    I have used a number of these dudes in Arizona as front and rear tires and they roll well, are durable, and the grip/rubber stamina combination is good...generally better than Maxxis in my experience.
    Not cheap though and not 2.6 although the 2.4 TK is a large volume tire.
    Leaning toward the 2.6 Rekon in the front and the 2.4 Ardent in the rear.
    Barely in control
    Feb 2007
    Quote Originally Posted by silentG View Post
    I've been scouring the German sites trying to figure out what happened to the 2.6 TK but no news yet!
    No Clue Crew
    Apr 2005
    I ride rocky gnar in tire-killing Phoenix. I do experiment on occasion, but have typically been a DHF 2.5/DHRII 2.4 guy on all my 29ers. These tires are consistent, give great traction and I can depend on them.
    On a whim, I picked up a Bontrager SE4 29x2.4 for the rear. Nice volume, about 160 grams lighter than the DHRII Exo TR it replaced.
    First ride was today up and down National Trail at South Mountain in Phoenix. Thus far, I'm impressed. Obviously too soon to tell about longevity, but excellent traction and pedaled really, really well on my Ripmo.
    Just like a raindrop, I was born to fall.
    Oct 2015
    Quote Originally Posted by Blatant View Post
    The 4s quickly became a dry favorite. We didn't get much of it this year. But hopefully next year will be better.
    Look at the Michelin Wild AM and Wild Rock'r2. While I don't have the Wild AM, I do have the Wild Rock'r2 and that thing sticks like glue to most everything.
    I'm not sure what size DHRII exo tr you had on but the SE4 29x2.4 claimed weight is 905g. To shave 160g off a DHRII exo tr the SE4 would need to weigh under 800g in one case or under 700g in another. Could you confirm?
    No Clue Crew
    Apr 2005
    The SE4 was 866 grams out of package (29x2.4). The 29x2.4 DHR WT TR Exo was ~1020 grams after I cleaned it.
    Thank you. The SE4 still has me interested but I was soo hoping you would confirm it was sub 800g.
    No Clue Crew
    Apr 2005
    I think that would be the XR4. I was stoked for mid-800s. If itís still alive 6 weeks from now, itíll be a winner.
    Reputation: WHALENARD's Avatar
    Feb 2010
    ^Yeah 866G is really really good for a tire with SE's reputation. I've not met anybody that doesn't like them. I think SE5/4 will be my next combo though the E-13 will be hard to top up front for my riding.
    It is no measure of health to be well adjusted to a profoundly sick society.
    No Clue Crew
    Apr 2005
    Checking back in. SE5 is still alive. Fingers crossed, but Iím pleased with this tire.
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    Magic Mary in now available in 29x2.6 soft. Would make a killer front tire with a hans dampf on the back.
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    Feb 2005
    My only issue with the 29er DHF 2.5 wt, now that Iíve just mounted it, is that itís puny compared to the Aggressor 2.5 wt. Granted, Iím coming off a 27.5+ Knobby Nic 2.8, but, especially for the weight, I feel like it could be a bigger volume. Itís actually a few mm narrower than the Aggressor at tread base and max nubby. Funny, bc I loved it on my previous bike, Tallboy, but at the time 2.3 was max aggressor. Spoiled with fattiness by now, I guess.
    Feb 2016
    Anyone tried the Aggressor 2.5WT out at the rear? I had mine now replacing the 2.3 version paired DHF 2.5WT upfront. I feel itís rather heavy now on the climb but when down, plenty of grip and give me the confidence.
    Nov 2017
    I had one on the rear. It was ok but wasn't a good roller. It was also heavy for me.
    change is good
    Sep 2004
    After the 2.5 wears a bit, it becomes faster IMO.
    Sent from my iPad using Tapatalk Pro
    No Clue Crew
    Apr 2005
    Bontrager SE4 still alive on the rear in Phx. Iím pretty stoked on this tire.
    100% PRIME ALBERTA BEEF
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Quote Originally Posted by Keithyk View Post
    Still deciding between a 2.5 DHF/2.5 Aggressor, and a DHF/DHF combo (2.5, 3C/DC). And then there is the 2.5 AssGuy EXO front and rear as soon as it becomes available. Decisions, decisions...
    Oct 2015
    Quote Originally Posted by mtnbkrmike View Post
    Im definitely leaning Ass guy Exo when they come out.
    Feb 2010
    Quote Originally Posted by Cerberus75 View Post
    That's rear specific though. Wouldn't run one up front.
    I would and will. Looks like a front tire to me.
    Feb 2010
    ^ Was joking on the spelling.
    Oct 2015
    Quote Originally Posted by WHALENARD View Post
    Oddly I got the sarcasm lol.
    Reputation: 27FIVE Dirt Surfer's Avatar
    Sep 2018
    Just switched to this combo(DHF 2.6/Agg 2.3) from 2.3 Shorty/DHR2 and wow its mean. In simular conditions ran with the DHR2 the Aggressor rolls better and grips as good over dirt,root and rock. DHF obviously kills the Shorty up front.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    I just recently switched to the Highroller 2 2.5 WT on the front of my bike and hvae really liked it so far. I decided to switch from minion DHF because my goal is to run the Ass guy up front when the EXO comes out and I feel the locked in edge feeling of the ass guy is more like the HR2 then the DHF. Plus the HR2 in 2.5 wt is quite a bike larger looking and feeling that the DHF.
    hispanic mechanic
    Reputation: sslos's Avatar
    Whiskey is my yoga.
    dongerparty.com
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Anyone who can compare the Bonti SE vs XR 4 ?
    Reputation: crissvaughn's Avatar
    Jul 2018
    Have swapped the 2.3 Agressor for the 2.4 DHR II. Even though good allround and very good enduro performance (at least according to tests), didn't work out for me at all. Was constantly slipping over the rear, missing traction, even in dry conditions. Maybe I'm not the target rider, but had real issues. Yes, the DHR II has more rolling resistance, but to me it's the sweet spot between Agressor and Highroller II.
    You can give the Ardent a try, but I doubt it will be rolling faster than the Agressor. So if you want to improve rolling resistance, you can go Ardent and / or Rekon and combine with the Agressor.
    cheers
    ​Rocky Mountain Thunderbolt 2016 Custom Built
    Mar 2015
    Quote Originally Posted by crissvaughn View Post
    cheers
    Interesting.
    I have always been a DHF/DHR2 guy, but I am throwing caution to the wind and going with a 2.5 3C DHF/2.5 DC Aggressor combo on my new HT, to try to shed some RR. Canít wait until spring to try it out.
    Jul 2018
    Interesting.
    I guess it's not (only) about the tyre, more about my skills. As I'm still an aspiring beginner after a long drought w/o a true mountain bike, I assume it's me lacking skill in corners to use the speed efficiently.
    The DHF upfront gives me a lot of control and confidence, so does the DHR II in the rear. As my bike is more on the quick and nimble side, maybe the Agressor's just too fast for me to handle.
    Definitely, the DHR II gives more support under wet conditions. That's no surprise however, and the Agressor is not to blame for
    Anyway, curious how that combination will work out for you in spring, especially on a HT.
  1. DHF 2.5 WT vs DHF 2.6 WT
    By SonomaBiker in forum Wheels and Tires
    Last Post: 12-11-2018, 09:50 PM
  2. Replies: 9
    Last Post: 02-13-2018, 02:06 PM
  3. DHF/DHF or another combo?
    By agreenbike in forum Wheels and Tires
    Last Post: 09-07-2017, 11:24 PM
  4. Dhf ust or standard dhf 2 ply for tubeless
    By trap121 in forum Downhill - Freeride
    Last Post: 06-04-2013, 10:08 PM
  5. Minion DHF/DHF or DHF/DHR for Downieville?
    By Taz8 in forum California - Norcal
    Last Post: 07-13-2007, 02:22 PM
Members who have read this thread: 340
