Results 1 to 3 of 3
    142 x 12mm E Thru axle alternatives
    I need a 142 x 12mm E thru axle for a 2016 Vitus Sentier. The best axle (price and quality)that I've found online is the DT Swiss RWS.
    I'd prefer an axle with hex bolts rather than the RWS lever. Is there any reasonably priced alternatives to the RWS?
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by fairwheel bikes
    The E-thru Conundrum: “E-Thru” is a Shimano-developed standard, with several variants sharing the E-Thru name. Fits are based on dropout thickness and use of internal threading or an external, replaceable nut. For example, a standard E-Thru 142 axle also fits on many E-Thru Boost 148 frames, while the standard E-Thru axle may be too long for many E-thru 142 frames because they require a shorter version. If possible, we strongly recommend using actual length measurements taken from your existing E-Thru axle when ordering a replacement. Don’t assume that because your frame is Boost 148 and uses E-Thru that it requires the E-Thru Boost 148 axle, as often it may not.
    All About Thru Axles - Fairwheel Bikes Blog
    I've read other people on this site complain about the DT rws and how the loctite fails eventually and it's a poor design. I have minimal firsthand experience, though, and can't cite my source.
    I have robert axle project axles on 2 of my bikes, and they work well.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Dec 2008
    I have been running the Hardlite 12 x 142 E thru axle on my Yeti for the last two seasons and it has been great. I would def get another.
    Attached Thumbnails Attached Thumbnails 142 x 12mm E Thru axle  alternatives-img_9563_1.jpg
  1. forwards compatible - 135 QR to 142-12mm thru-axle
    By cdn-dave in forum Wheels and Tires
    Last Post: 08-17-2016, 03:51 AM
  2. Replies: 2
    Last Post: 09-14-2015, 04:55 PM
  3. Quick release vs 10MM thru vs 12MM thru axle
    By ScabFace in forum General Discussion
    Last Post: 08-25-2013, 11:36 AM
  4. Replies: 2
    Last Post: 06-17-2013, 06:48 PM
  5. 12mm x 142+ thru-axle hub replacement
    By jmang in forum Specialized
    Last Post: 09-06-2012, 08:05 AM
Members who have read this thread: 29
