130 or 135mm non-disc rear 9sp casette hub with nutted axle. Or bolt-up. Or...- Mtbr.com
Results 1 to 6 of 6
    Hi. I have a problem with rear wheel on my Surly Cross check. When gear is little to high, rear wheel slides in the dropouts, goes of the line and tire rubs chainstay.
    So, i decided to use nutted rear axle hub, but I can't find any... Can anyone suggest some models, so I can start googling it ?
    Or, suggest a rear skewer, that holds wheel REALLY TIGHT.
    Thanks.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by nameresu View Post
    Thanks.
    Shimano QR skewers have the best clamping power. You can also find "security" bolt-on skewers.
    For hubs, most Shimano hubs can be fit with a solid bolt-on axle.
    mtbtires.com
    Thanks, but can you suggest something with sealed cartridge bearings ?
    And about skewers... Just any shimano, or specific ones ? alivio, deore, xt, xtr, slx?
    Dec 1998
    Chris King with Fun Nuts.
    Any skewer mid-level or higher.
    mtbtires.com
    Ouch! Cheap Shimano and pricey Chris King and nothing in between. I will try shimano skewer first...
    Reputation: Bike Whisperer's Avatar
    I got Ultegra hubs that are going on their second decade...cup and cone bearings hold up just fine and you can convert the Ultegra (130mm spaced) to a solid bolt on axle easily.
    Could always go Hope Pro 3 Mono hubs with a 10mm thru bolt...more than Shimano but less than King
